Why does this filter have two capacitors? And other queries.
Page 2 of 2 [26 Posts]
Goto page: Previous 1, 2
Werebear
PostPosted: Tue Jun 04, 2013 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
after following this thread here's my variations.
Voltage control is achieved with a BC 547 with a 100K resistor across it as in the pic synth filter. The mix resistor on the gate of the transistor started as 1M as in Jinglejoes sketch but fiddling around I found 10K gave a good sweep. The frequency pot will need a range resistor to ground but haven't tried it out yet, but the range on the pot is nearly the full turn.
Looking at Tim Escobedos Q+D VCF, the second variant has caps of different values and remembering what Joe said about the position of the caps having an effect on resonance I played around with values until I got something that sounded good to my ears. In an attempt to have some play in the range of the resonance pot I used a 1K pot in the hope that the range wouldn't be squashed into the last few degrees of turn. It kinda isn't but would like to use a smaller value pot still. I also experimented with using a separate cap with a pot, 470 pF and a 10K, but that didn't work so well.
I've played with this type of filter before without much success but after reading this thread and with the Jingle man's sketch I bread boarded it up and it worked first time! Playing with it was a process of swapping out components until I got something pleasing to my ear and a satisfying twiddle factor.
Thanks to everyone who took time to demystify twin T VCFs.
 Filesize:  740.3 KB
 Viewed:  241 Time(s)
I think I like it. Does it matter if I don't?
