  bingsatellites Mostly Ambient
ADSR end trigger
Page 1 of 1 [8 Posts]
Pehr
PostPosted: Mon Dec 19, 2011 7:05 am    Post subject: ADSR end trigger
Subject description: inspired by the 281
Would it be possible to add an end of cycle trigger when the release is finished on the MFOS ADSR?
That would be really good because I could use my 4 ADSRs as LFOs like the 281 Smile
First thought is to just ook up some MML cuircuit from Ray:
(upper-right)
to the (R) point (U2-D pin 11) in this schematic:
Possible?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
iopop3
PostPosted: Mon Dec 19, 2011 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool idea, can not see why it would not work. Quite a few parts so it should be rather easy to test.
Pehr
PostPosted: Mon Dec 19, 2011 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
and the ADSR already has three hex inverter/schmidt triggers unused!
(U3-BCD)
YouTube channel
flickr photostream
iopop3
PostPosted: Mon Dec 19, 2011 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Just do it! Very Happy
.. and report back your results.
Mongo1
PostPosted: Mon Dec 19, 2011 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let us know if that works!
BTW, I already used one of those spare invertors to drive an LED. I hooked one side up to the "A" signal and the other to the LED. Now I have nice blinky lights, and you KNOW how important that always is....
Gary
Pehr
PostPosted: Mon Dec 19, 2011 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
0k, after some investigation I've realised that the release phase does not end until the gate is high and the attack begins.
to be continued...
YouTube channel
flickr photostream
Pehr
PostPosted: Mon Dec 19, 2011 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
0k, I got it oscillating without modifying
Send the output to an inverter (CGS NOR) and then the inverted back to the trigger input.
However...
* it is an RC-envelope, thus RC-wave
* it is hard to control frequency at audio rates
* it is oscillating from 2V to 10V due to the input comparators
good enough for me Smile
YouTube channel
flickr photostream
Pehr
PostPosted: Tue Dec 20, 2011 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
0k, it is possible to have an EOA-trigger out (End Of Attack) without massive modification.
That way I could get quadrature-ish CV combined with other envelopes. Smile
or HADSR if you like
YouTube channel
flickr photostream
AmbiphonicDSP
