Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Tue Apr 02, 2013 12:37 pm Post subject:
Dogenigt wrote: |
I am integrating the 4046 module into a larger lunetta synth - so only square waves will come in, do you think the 4049/4069 will add something to the sound even though the signal is squared in the first place anyways?
of course I could just test this out myself, I might anyhow but I don't see how you could "square up" a signal which is already squared... |
I've built my first tracker just like it is in the Nic Collins book; with the 4049 as preamp. Realistically, it's not essential in our lunetta since most of the stuff we will push through the 4046 will already be square/square-ish. My more recent tracker builds don't use the 4049 and work just as well as my first one.
That said, I have heard slight variation in sound when I sweep the 4049 gain pot. Adds a bit of hair to the sound but not a must build .
With the 4049 and say a 1/4 jack wired to accept input from a guitar, mic, etc., the addition of non square signals can be accomplished. (I need to diagram that sentence). _________________ Zontar Prevails! |
Dogenigt
Posted: Tue Apr 02, 2013 5:58 pm Post subject:
[quote="Draal"] Dogenigt wrote: |
With the 4049 and say a 1/4 jack wired to accept input from a guitar, mic, etc., the addition of non square signals can be accomplished. (I need to diagram that sentence). |
Yeah, I've got my own copy of Handmade Electronic Music
It's a brilliant idea though and included in my future build no doubt! _________________ www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein |
Dogenigt
Posted: Tue May 21, 2013 10:56 am Post subject:
I am having a little headache about something here.
I want to have diodes on my 40106 pulse outputs for mixing but when I connect this output through the diode to the input of the 4046 it doesn't work. It's like there's no input.
I could mix with resistors but then the voltage drops from my reference HIGH doesn't it? (9V in my case) _________________ www.dogenigt.com
-minus-
Posted: Tue May 21, 2013 11:00 am Post subject:
Try a 100K resistor to GROUND after the diode. See if that works. |
Draal
Dogenigt
Posted: Wed May 22, 2013 2:10 pm Post subject:
Thanks guys! I solved this buy running the "dioded" signal through a schmitt trigger (40106) _________________ www.dogenigt.com
izash
Posted: Fri Aug 12, 2016 5:19 am Post subject:
CD4046 |
Output 1 sounds amazing. Output 2 sounds great too but seems to respond to the negative edge of the pulse. great delay effect!
Here I am 4 years later. Thank you guys for some amazing ideas.
synthesist wrote: | hey
did anyone try to listen to the output of pin1 and pin2 on the cd4046?
Cause I made some similar circuits like the pitchtracker and if you are lucky you get to here this weird bitcrushing-like sound on these outputs. |
Draal
Posted: Mon Sep 05, 2016 3:42 pm Post subject:
Re: CD4046 |
izash wrote: | Output 1 sounds amazing. Output 2 sounds great too but seems to respond to the negative edge of the pulse. great delay effect!
Still one of my favorite chips to work with. Now, back to my crypt... _________________ Zontar Prevails! |
