mfos 10step vs. 16 step sequencer advice
Page 1 of 1 [8 Posts]
wallace
PostPosted: Sat Dec 24, 2011 6:03 pm    Post subject: mfos 10step vs. 16 step sequencer advice Reply with quote  Mark this post and the followings unread
Hi everyone, I recently finished putting together a soundlab, which was my first synth project. I'm not very experienced with electronics, but I finished the soundlab with no problems. Just wondering how big a jump it would be to take on the 16 step. Think I should play it safe and get some more experience building the ten step?
RF
Audio files: 28
PostPosted: Sat Dec 24, 2011 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
No reason to settle - If you did a soundlab, You can do the 16 step sequencer...
www.sdiy.org/rfeng
inlifeindeath
PostPosted: Sun Dec 25, 2011 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
after the soundlab, i went with the 10 step and regret not doing the 16 all the time. I wish I could use an external clock, which isn't available on the 10. I'd say go for it! if you have the will, you'll get it done!
ashleym
PostPosted: Wed Dec 28, 2011 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Well done for finishing the Soundlab as you first project.
Go for the 16 step sequencer, you will be able to build it. I am building one at the moment. It is a little bit more complicated than the 10 step seq but easier than the Soundlab.
Think how music divides in bars, 16 steps work for all the common 4/4 and related but you can also set it to 12 steps for 3/4 etc.
I am also building the quantiser at the same time and I am combining the two. I am doing this so when I use the sequencer to play melodies I dont have to worry about the exact tuning of each step. If I am using the sequencer to control filter cut off or something similar I dont have to use the quantiser. Please ask if you need to know more.
wallace
PostPosted: Tue Jan 03, 2012 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the advice guys, guess I'll go for it!
Man, this has gotta be the most helpful forum on the web, and possibly the only one devoid of bs attitudes!
Are you all using a power supply with this thing? yet another realm I have no experience with yet
loydb
PostPosted: Tue Jan 03, 2012 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
MFOS's wall-wart power supplies are fast, easy builds.
wallace
PostPosted: Tue Jan 03, 2012 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, I'm ordering the parts for the power supply now. There don't seem to be any AC power jacks on Jameco or Mouser, just DC. Is that the thing to use?
The actual science of all this is a bit over my head. Hope I don't electrocute myself!
prgdeltablues
PostPosted: Mon Jan 09, 2012 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
You need AC output NOT DC.
Mouser UK part no: 553-WAU12-1500 is the sort of thing (listed under Power/Plug-In AC adapters.) 12V AC output, rated at 1 or 1.5 A.
Ideally you want a linear rather than switching wall-wart, but that will get you started.
Peter
