Lunetta power supply
Page 1 of 1 [7 Posts]
deadbeat
PostPosted: Fri Dec 30, 2011 6:16 pm    Post subject: Lunetta power supply Reply with quote  Mark this post and the followings unread
Hi everybody !
i'm building my lunetta network actually, and was wondering why most people who build lunetta stuff uses 5v power supply...
I'd like mine being able to interact with Karplus Strong or Quad Bass ++, which work with higher voltages...
I think that i have to power my lunetta stuff the same way ( even if it won't use negative supply) as these modular modules if i want them to be synced or triggered ...
Thanks for your answer !
http://h.a.k.free.fr/
http://virb.com/dead_beat
http://virb.com/bend_over_boysfriends
JingleJoe
PostPosted: Sat Dec 31, 2011 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Because that is the required supply voltage for the chips used. Some chips can handle higher, often between 3 and 15 volts. But some others only work on a 5 volt supply. All depends on the chips you are using, you'll have to check your datasheets.
Also, look up voltage regulator IC's.
deadbeat
PostPosted: Sat Dec 31, 2011 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jingle Joe !
But i was sure that all the cmos stuff ( CD****) would work btw 5 & 15v...
If i power lunetta with 5V, if i use a R2R ladder, would the cv fit for feeding a quad bass CV ?? Maybe yes, but i wouldn't give all the quad bass abilites, no ?
thx
fluxmonkey
PostPosted: Sat Dec 31, 2011 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i stick w/ 4000 series chips specifically for this reason, they generally are good between 3 and 15 volts. usually i build lunetta stuff as standalone boxes i usually use 9v battery power... used as a sound source in conjunction w/ a modular, the levels are fine. everything i've ever tried worked fine on 15v, tho some of the oscillator frequencies shift a bit based on the voltage level... but since most of my lunettas are pretty noisy and don't include ferrites and power conditioning, keeping them on batteries or a separate PS help isolate the modular power grid...
b
www.fluxmonkey.com
JingleJoe
PostPosted: Sat Dec 31, 2011 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't ask us, you're the one who should know the specifications of your own equipment Laughing I don't even know what quad bass CV is, I assume it's some kind of voltage controlled four legged fish?
RF
Audio files: 28
PostPosted: Sat Dec 31, 2011 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I switched my Lunetta power to 12 v from 5 because I wanted to use it with other bits - including the quad Bass++
bruce
www.sdiy.org/rfeng
deadbeat
PostPosted: Wed Jan 04, 2012 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, thanks all !
i think i'll use 15v, and add some power regulator after r2r ladder. Like that i'll be sure it can be used with all the stuff i want without any problems !
