FWD/REV Sequencer
Audio files: 107
PostPosted: Wed Feb 09, 2005 9:22 am    Post subject: FWD/REV Sequencer Reply with quote  Mark this post and the followings unread
This is Rob Hordijk's sequencer that goes back and forth. The building block is in green. The modules with inputs are in bright green. The gray modules are to show how to use the building block.
The fwd/reverse can be manually controlled with the button on the Direction module, or electronically controlled with an input which is connected to input 2 on the Sw2-11 module. The switch on the Sw2-11 module enables the automatic mode, or manual mode.
At the bottom of the building block is a circuit to make the output gate or trigger. Use the Trig/Gate module for this.
[This was uploaded from a beta version of the editor and G2 OS. Please let me know if there are problems and I'll figure out how to get this in a more compatible format]
HowardSequencer.pch2
FWD/REV sequencer building block
 Filename:  HowardSequencer.pch2
 Filesize:  2.94 KB
 Downloaded:  1172 Time(s)
JuneSolstice2013
