 Forum index » Artists » Antimon
Doodles II - tracks
Post new topic   Reply to topic Moderators: Antimon
Page 1 of 1 [14 Posts]
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 10:23 am    Post subject: Doodles II - tracks Reply with quote  Mark this post and the followings unread
I made a record called "Doodles" that I put up on iTunes via TuneCore (besides a number of US streaming sites), and later SoundCloud. As it was released, I did a show here on radio.electro-music.com where I talked a bit about each track and played all tracks from the album.
Doing that show was lots of fun and made me want to do it again, so I gathered some other tunes I had lying around, polished them a bit, and broadcast them in another show, which you can find here. Most of these tracks can't be easily found elsewhere, so I'm going to post them here.
I'm not sure of which order I played these, and I've lost the playlist it seems, so I'm just going to post the main tracks alphabetically, according to the filenames they got.
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Bilging Duty takes it's name from a chore you can do in Puzzle Pirates, which I was into at the time. I think it's mostly Ableton Live instruments controlled manually from a keyboard, and some other stuff, chugging along.
Bocca Lika takes it's name from the fact that I thought, at the time, that part of it got a bit of a Boards of Canada vibe. I don't really see that now... anyway Boards of Canada is a great inspiration and I try to sound like them every now and then. Trying something and failing is one way of getting somewhere.
Corridors builds up slowly using arpeggio riffs and stuff that generally repeats. It's a sombre affair, a bit like stuff I made later on the Commuter's Diary tracks. 7 minutes - longer than usual for me on a track like this.
Curetronic premiär is the first thing I did after I had gotten my Curetronic modular put together. I think everything including the percussion is done by adding track after track of modular sequences and tweaks.
Follow the String through the Fog is a simple track featuring a kind of Euro Techno bass that I sometimes can't resist using.
Bilging Duty cropped.mp3
 Filename:  Bilging Duty cropped.mp3
 Filesize:  4.79 MB
 Downloaded:  250 Time(s)
bocca lika.mp3
 Filename:  bocca lika.mp3
 Filesize:  10.64 MB
 Downloaded:  247 Time(s)
Corridors.mp3
 Filename:  Corridors.mp3
 Filesize:  16.13 MB
 Downloaded:  262 Time(s)
Curetronic permiär.mp3
 Filename:  Curetronic permiär.mp3
 Filesize:  5.66 MB
 Downloaded:  257 Time(s)
Follow the String Through Fog.mp3
 Filename:  Follow the String Through Fog.mp3
 Filesize:  6.24 MB
 Downloaded:  243 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Usually when I record a song into the DAW, it gets a filename that indicates what instrument was mainly used (unless it has a song part with lyric, in which case I'll give it a name from the lyric), with a number added at the end. Then when I decide to mix it down properly and show it to someone I'll give it a name. Since "git1" was only shown to someone when I put together the Doodles II show, it never got a fancier name than that. Anyway, it's a guitar-heavy instrumental, as the name indicates, with a static noodle thing in the background. This is a kind of music which I feel is in danger of falling between labels, and it's difficult knowing if it will be appreciated, say, here, or in a rock forum or whatever. I'm happy with it at any rate, though it could be fleshed out and varied a bit.
I was pretty sure I had put up "I Remember You" somewhere, but it doesn't seem like it. Anyway, it has a melancholy TV-feel, an instrumental mix of synth and guitar sounds. I struggled a lot with the bass guitar part, I wish I could have been able to do a better job with that.
Kinda Counterpoint is a silly thing... I struggle getting my head around counterpoint, what it means, and how you do it. I put this in as a transition thing between tracks.
Listen to Me is another thing I did after getting my modular set up - possibly also the MFOS SoundLab Ultimate that I made shortly after getting the Curetronic. It's a melancholy melody with arps and stuff.
"modular" is another track which never got the honor of having a better name. It's mostly a kind of broken bass riff, a flowing percussion and some wackiness.
git1.mp3
 Filename:  git1.mp3
 Filesize:  7.89 MB
 Downloaded:  252 Time(s)
I Remember You.mp3
 Filename:  I Remember You.mp3
 Filesize:  9.38 MB
Kinda Counterpoint.mp3
 Filename:  Kinda Counterpoint.mp3
 Filesize:  1.53 MB
 Downloaded:  251 Time(s)
Listen To Me.mp3
 Filename:  Listen To Me.mp3
 Filesize:  7.32 MB
 Downloaded:  259 Time(s)
modular.mp3
 Filename:  modular.mp3
 Filesize:  2.92 MB
 Downloaded:  232 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
"Pace Your Eyes" is a pop song that ended up on a collection of pop/rock tunes called "Tailors", which you can find here. I included it in the Doodles II show before that. The piano sound was made by having a MIDI controller play a piano sound on a rompler as well as an Arturia Origin patch simultaneously, the piano going into the Origin which gated the whole sound while doing some filtering stuff, leading to a weird attack/release effect. I'm generally annoyed at the Origin's way of dealing with this gating stuff, but that's another thread. :/
Repetitive Weak is a minimal thing that probably works better as a transitoire than on its own, though I like the bass sequence. Could be fleshed out more.
Sink into It features more guitar, probably a lot of Evolver and strange percussion.
Sombre explains itself - more sombreness, guitar and light percussion.
The Lagoon - I chose that name from the feel of the start of the tune, before guitars barge in and break the tranquility.
Pace Your Eyes.mp3
 Filename:  Pace Your Eyes.mp3
 Filesize:  8.67 MB
 Downloaded:  255 Time(s)
Repetitive Weak.mp3
 Filename:  Repetitive Weak.mp3
 Filesize:  6.73 MB
 Downloaded:  244 Time(s)
Sink into It.mp3
 Filename:  Sink into It.mp3
 Filesize:  8.11 MB
sombre.mp3
 Filename:  sombre.mp3
 Filesize:  8.03 MB
 Downloaded:  265 Time(s)
The Lagoon.mp3
 Filename:  The Lagoon.mp3
 Filesize:  5.38 MB
 Downloaded:  258 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
They Used to Live Upstairs uses one sequence and has stuff dance around it. I'm happy with the main sounds, off the Poly Evolver.
Togetherpoint was made right after "Kinda Counterpoint" above, trying a different approach, having sequences touch each other here and there. Or something. I think it's all done on the modular(s), with an MXR Carbon Copy analog delay ringing in the background.
Welcome Light is an Evolver-heavy track with a nice melody that I'm happy with.
vg99 was done on the... wait for it... VG99! The main piano line was played using the VG99's MIDI output.
vg993 is another VG99 track, trying out a synth sound on a melody I came up with. I added some effects in Live afterwards to take some of the harshness out of the sound. If it had crossed my mind, I probably would have added some EQ as well.
They Used to Live Upstairs.mp3
 Filename:  They Used to Live Upstairs.mp3
 Filesize:  9.63 MB
 Downloaded:  253 Time(s)
togetherpoint.mp3
 Filename:  togetherpoint.mp3
 Filesize:  6.96 MB
 Downloaded:  245 Time(s)
Welcome Light.mp3
 Filename:  Welcome Light.mp3
 Filesize:  6.6 MB
 Downloaded:  256 Time(s)
vg99.mp3
 Filename:  vg99.mp3
 Filesize:  3.99 MB
vg993.mp3
 Filename:  vg993.mp3
 Filesize:  6.42 MB
 Downloaded:  254 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is Love is a song consisting of (I think) a Nord Modular G2 key sound and a quiet vocal.
Where Are My Keys Where Do I Live is another transitoire track, even though I'm happy with the slanted drunken sound.
Whitewashed Labyrinth is an example of when I come up with a short cyclic melody/bass thing that I like, though I struggle to carry into a larger environment, ending up with a brief thing like this, with a kind of forced middle section where I tried to add some variation. :/
You Can Leave Me Now is another track that ended up in the Tailors collection. It's very pop, but I put in a lot of work on it and I'm quite happy with the result.
What is Love.mp3
 Filename:  What is Love.mp3
 Filesize:  4.84 MB
 Downloaded:  276 Time(s)
Where Are My Keys Where Do I Live.mp3
 Filename:  Where Are My Keys Where Do I Live.mp3
 Filesize:  4.12 MB
 Downloaded:  280 Time(s)
Whitewashed Labyrinth.mp3
 Filename:  Whitewashed Labyrinth.mp3
 Filesize:  4.45 MB
 Downloaded:  277 Time(s)
You Can Leave Me Now.mp3
 Filename:  You Can Leave Me Now.mp3
 Filesize:  8.09 MB
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Above are all of the main tracks in the Doodles II collection. For the show I made some transition tracks that were meant to be mixed in between the tracks. They're mostly just simple drones or sequences done on the modular. I'll post them here too.
Actually, inbetweener3 is kind of fun. Smile
curetronic2 intermediate.mp3
 Filename:  curetronic2 intermediate.mp3
 Filesize:  5.8 MB
 Downloaded:  248 Time(s)
inbetweener1.mp3
 Filename:  inbetweener1.mp3
 Filesize:  4.27 MB
 Downloaded:  263 Time(s)
inbetweener2.mp3
 Filename:  inbetweener2.mp3
 Filesize:  4.27 MB
inbetweener3.mp3
 Filename:  inbetweener3.mp3
 Filesize:  940.89 KB
 Downloaded:  246 Time(s)
inbetweener4.mp3
 Filename:  inbetweener4.mp3
 Filesize:  1.83 MB
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
inbetweeners 5-9
inbetweener5.mp3
 Filename:  inbetweener5.mp3
 Filesize:  1.38 MB
inbetweener6.mp3
 Filename:  inbetweener6.mp3
 Filesize:  1.22 MB
 Downloaded:  273 Time(s)
inbetweener7.mp3
 Filename:  inbetweener7.mp3
 Filesize:  1.38 MB
 Downloaded:  264 Time(s)
inbetweener8.mp3
 Filename:  inbetweener8.mp3
 Filesize:  784.91 KB
inbetweener9.mp3
 Filename:  inbetweener9.mp3
 Filesize:  784.91 KB
 Downloaded:  274 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jan 06, 2012 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
And that was all of Antimon's Doodles II! Smile Hope you have enjoyed some of them.
audiodef
Audio files: 27
PostPosted: Fri Feb 24, 2012 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
May I pretty please put these on Synthetronica Radio?
Audiodef
Synthetronica
Gentoo Studio
Audio files: 211
G2 patch files: 92
PostPosted: Sat Feb 25, 2012 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure! I give you permission to play any track that I post here on Synthetronica. Smile
audiodef
Audio files: 27
PostPosted: Mon Feb 27, 2012 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! Very Happy
Audiodef
Synthetronica
Gentoo Studio
Johan Zwart
PostPosted: Sat Mar 31, 2012 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice doodling. Cool
www.jzwart.eu www.myspace.com/johanzwart www.myspace.com/themissinghiggs
audiodef
Audio files: 27
PostPosted: Mon Apr 02, 2012 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
All the doodles have been put on Synthetronica Radio's main playlist. Cool
Audiodef
Synthetronica
Gentoo Studio
