  bingsatellites Mostly Ambient
Lame INI file for the edcast reborn winamp plug in
Page 1 of 1 [2 Posts]
darkvortex
Audio files: 47
PostPosted: Mon Jan 09, 2012 3:42 am    Post subject:  Lame INI file for the edcast reborn winamp plug in Reply with quote  Mark this post and the followings unread
I've come across a few people who have been having trouble getting the edcast WinAMP plug in to broadcast at a constant bitrate. So here's the INI file that you need to include in the WinAMP program file directory (where lame_enc.dll lives) which will force the bit rate to 128k CBR.
I use this configuration regularly on the open port and it's very stable. Har has also reported it to work well when broadcasting on Still Stream.
Hope this helps someone at some point.
Cheers, Joel... Smile
lame_enc_ini.zip
 Filename:  lame_enc_ini.zip
 Filesize:  983 Bytes
 Downloaded:  97 Time(s)
audiodef
Audio files: 27
PostPosted: Mon Jan 09, 2012 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't use Windows, but I think it's great of you to share this. Very Happy
If anyone else uses Linux, I'm perfectly happy to share any of my configuration settings, assume I'm using the same software.
Audiodef
Synthetronica
Gentoo Studio
Niio1
