Zap
Posted: Wed Jan 11, 2012 11:48 am Post subject:
Triggering a zoom sampletraks pads by midi-trigger Subject description: looking for hints where to start |
Hi guys,
i'm new to hardware modifications and until now have not much skills in electronics (besides some soldering experience) and would like to get some hints where to start my quest:
I'm looking for a solution to add midi triggering of the pad actions of a zoom sampletrack.
The sampletrack lacks the midi spec to trigger songs, but it is possible on the hardware itself using the pads on the machine.
Can anyone give me some starting points what i could do to analyse signals, find the right spots for wireing some triggers and midi/trigger hardware which could be suitable for such a task ?
Appreciate your help.
Best Regards,
Zap |
PickNick
Zap
Posted: Wed Jan 25, 2012 2:44 pm Post subject:
Hi PickNick !
Great to get an answer, thank you very much for your hints.
I even can by the Midi-trigger here in Germany from:
http://www.touched-by-sound.com/de/Keyboards-39704-Dtronics_MTrig_V2_Midi_to_Trigger_interface.html
So if i understand right, this will create some kind of voltage peak signal that has to be converted to a short circuit (which is what the pads actually do) ?
What i really like about that is that it doesn't cost much money, so i will definitely give it a try (if i found out where to connect the swiches ...)
Many thanx,
Zap |
PickNick
Posted: Thu Jan 26, 2012 9:20 am Post subject:
yes. this converters are usefull to triggering analog drum modules, EGs...
some old synths works with S trigger/switch and some of them with V trigger/voltage.
sometimes these buttons made from the PCB traces///there is no real switch
and they put some conductive materials to the plastic pad.
its a cheaper way.
this is why these switches stop to working if there is some dirt between the
two surface.
http://www.openmusiclabs.com/wp/wp-content/uploads/2011/10/keyboard_button_med.jpg
if your Zoom have this kind of switch than you have to find those two traces on the PCB.
good luck!
p _________________ Allow theex.nl |
Zap
Posted: Fri Jan 27, 2012 2:41 pm Post subject:
The contacts in the zoom are working just this way (but with a bigger surface area and a snake like contact on the pcb). But there are no nice places to solder some wires to. I will have a look whats going on at the connector going from the pads pcb to the main pcb.
btw: do you by chance know which latency the aforementioned midi-trigger interface has ?
Would somethink like an alesis trigger i/o also work to do this job ?
Stephan |
Audio files: 215
G2 patch files: 92
PickNick
Posted: Sun Jan 29, 2012 2:43 am Post subject:
woow!
thx Antimon:)
Zap!
i think there is no notable latency, because these are using
really fast microcontrollers.
you mean this?
http://www.alesis.com/triggerio
$159.00...hmmm
its quite a lot of money...
i found this german site:
http://www.mikes-elektronikseite.de/mshop_deutsch/
they are selling Midibox pcbs, kits, parts etc...
i built few of them///Midi2CV, SID synth, Midicontroller, MidiSequencer,
and so far these are the best open source Midi Modular heaven:)
if you buy a midicore+dout4, than you get 64 trigger outs!
don't waste your money for buying some good looking toys!
buy some electronic parts and you can learn a lot!
DIY...this is why you are here:)
p
sorry for my poor english...speak english or DIY:)
http://www.youtube.com/watch?v=o7rpVRnuAcQ _________________ Allow theex.nl |
Zap
Posted: Sat Feb 04, 2012 4:12 pm Post subject:
Hi PickNick!
Found some connector on the sampletraks pcb, where shortcircuting each of the wires with some other places on the pcb will trigger the different pads.
So i think i can proceed ...
Is there also something like http://www.engineersatwork.nl/dtronics/pages/midi_to_trigger_interface.html which also can gate ? midi note on/off = push/release pad ?
Thank you so much for your help,
Zap |
PickNick
Posted: Sun Feb 05, 2012 6:27 am Post subject:
Hi Zap!
| Quote: | Found some connector on the sampletraks pcb, where shortcircuting each of the wires with some other places on the pcb will trigger the different pads.
So i think i can proceed ... |
zuppa!
Has 23 trigger outputs ( 5 volt positive puls, selectable 1ms or 10ms per pulse )...
there is no gate, just a trigger which can be 1ms or 10ms long.
imagine a piano roll... the trigger outs from c2 to a#3.
doesn't matter how long you hold a key, the midi2trigger will send just a pulse on the midi note on. for release pads you need a logical circuit which is
acting like a switch. than you can make some "gate" between two triggers. the first trigger will switch to hi the second will switch to low the circuit.
soon i will send some schematics or links...but now i have to open my laptop PSU with a saw...aaargghhh _________________ Allow theex.nl |
Zap
Posted: Sun Feb 05, 2012 9:57 am Post subject:
Hi PickNick
Dont hurt yourself  |
PickNick
Zap
Posted: Mon Feb 06, 2012 2:39 pm Post subject:
i have a Doepfer MCV1 lying around here, which can be set to switch-trigger
It has only one trigger out, but this way i can test if it will work
Would like to have one of those:
http://www.cykong.com/Synths/Doepfer%20MCV8/Doepfer-MCV8.htm
Stephan |
