Sound affecting knobs and buttons stopped working!
Page 1 of 1 [4 Posts]
Synthbrass
PostPosted: Mon Jan 16, 2012 8:22 am    Post subject: Sound affecting knobs and buttons stopped working! Reply with quote  Mark this post and the followings unread
I did some MIDI experimenting with the A6 and than it froze on one sound. I switched it off and on again and than everything seemed to be fine. But than when I wanted to tweak the sound, I noticed that I can't change Waveform. I tried out all buttons and knobs but only the keyboard, the wheels, the volume knob and the global, program, mix, store etc buttons work. I can change program and change global settings but I can't tweak the sound in any way.
What can I do?! Sad
Synthbrass
PostPosted: Mon Jan 16, 2012 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I fixed the problem Very Happy Thread can be deleted, or closed or whatever.
Mefistophelees
PostPosted: Mon Jan 16, 2012 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
How did you fix it?
http://soundcloud.com/Mefistophelees
Synthbrass
PostPosted: Mon Jan 16, 2012 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, nothing special. On the Global settings in the Panel section I had accidently switched TXMODE to MIDI, instead of local. I switched it to local and it worked. Very banal mistake Embarassed
emSynth
