PCBs for the fonitronik Sequential Switch (4th run)
Page 1 of 1 [21 Posts]
PostPosted: Fri Jan 27, 2012 4:42 am    Post subject: PCBs for the fonitronik Sequential Switch (4th run)
Subject description: taking advance orders until 13 FEB 2012
EDIT Feb 6th:
i will take advance orders until Feb 13th
ETA of the PCBs would be early march. i won't take any money until i hold the PCBs in my hands. i will contact you concerning payment details when time has come. paypal preferred.
again some of you indicated interest in this project, so i would do a 4th run if there would be interest in more than at least 30 PCBs.
BTW i think this module will be a good companion for the symplSEQ.
simply post in this thread, contact me via email or even PM, and tell me how many PCBs you will take. BTW i won't take any money until i hold the boards in my hands...
i personally think it is a very useful module. it provides one output/input that can be routed sequentially to four inputs/outputs. the step and reset of the switch can be controlled manually and/or by a clock. the number of steps is selectable (2, 3 or 4 steps), which is very nice if you want to switch live between different sources/destinations. all signals between -15V and +15V can be switched, due to the DG412 (or MAX313) IC used.
here you will find the latest documentation:
Building Docs
PRICING:
each PCB 10.-USD/7.-EUR
+ packaging & postage
deutschland: 1 PCB 1.-EUR, 2+ PCBs 1.50 EUR
europe: 2 PCBs 2.-EUR, 3+ PCBs 4.-EUR
outside europe: 2 PCBs 4.-USD, 3+ PCBs 6.-USD
this is how it could look like:
SeqSwitch fonitronik.de
fonitronik at
Mongo1
PostPosted: Fri Jan 27, 2012 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 3 - they look pretty useful...
Thanks
Gary
inlifeindeath
PostPosted: Sat Jan 28, 2012 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me please
aladan
PostPosted: Wed Feb 01, 2012 8:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 please
Any suggestions where I might pick up a few DG412 or MAX313 cheaper than Futurelec (MAX313 @ $5.90 each?)
ejr27233
PostPosted: Thu Feb 02, 2012 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 2 please
mark_olson
PostPosted: Mon Feb 06, 2012 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias: I haven't actually added it up, but it's looking like between here and Muff's you may hit your minimum!
Count me in for 2.
Thanks for considering another run; I was disappointed that the last one came during a self-imposed moratorium on adding to my backlog!
Mark
PostPosted: Tue Feb 07, 2012 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
indeed. it wil happen. i will have to list al pre-orders up, and then i will set a cutoff date. from then on the delivery date is fixed...
fonitronik at
citric acid
PostPosted: Sat Feb 11, 2012 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi,
as i wrote in an old treat , i wan´t 2 please !
http://soundcloud.com/citric-acid-303
keithwin
PostPosted: Thu Feb 16, 2012 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blimey, only just seen this again, I would like three if not too late?
PostPosted: Thu Feb 16, 2012 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
have some spares, so no problem at this point.
fonitronik at
keithwin
PostPosted: Fri Feb 17, 2012 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a definite from me, thankyou
textual
PostPosted: Mon Feb 20, 2012 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you have any remaining at this point?
______________________
www.dlbelectronics.com
www.textualmusic.com
www.mercuryprogram.com
PostPosted: Mon Feb 20, 2012 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes.
fonitronik at
janvanvolt
PostPosted: Sat Mar 03, 2012 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
For the sake of my sympleseq: i'd like to take one PCB of the seqswitch .-)
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
mark_olson
PostPosted: Sat Mar 03, 2012 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Did I miss this? Or is it still forthcoming?
Mark
PostPosted: Sun Mar 04, 2012 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
it happens right now. the PCBs should arrive soon, and i ordered some spares as always. so still time to jump on the bus.
fonitronik at
mark_olson
PostPosted: Sun Mar 04, 2012 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
...still time to jump on the bus.
I'll take two!
(If this isn't enough of a commitment, or if you want prepayment, let me know.)
Mark
PostPosted: Wed Mar 14, 2012 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
now all PM's/emails are sent.
if you have the feeling you missed something or i missed to contact you, just let me know... there are spares avilable.
fonitronik at
keithwin
PostPosted: Tue Mar 20, 2012 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards waiting for me at work this morning, very smart, many thanks Matthias.
PostPosted: Tue Mar 20, 2012 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
you have a soldering iron at work? Very Happy
fonitronik at
keithwin
PostPosted: Tue Mar 20, 2012 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Wish I had, would solve all sorts of problems :0)
The soldering I do at work needs significantly higher temperature, platinum for example Smile
mps board
