Parallel / Serial filter 'building block'
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Feb 12, 2005 3:58 pm    Post subject: Parallel / Serial filter 'building block' Reply with quote  Mark this post and the followings unread
Here is a building block patch that is similar to the parallel / serial filter routing scheme on the Waldorf Q. It uses a 12dB lowpass filter and a 24dB multimode filter, with single-knob control to gradually change the routing from parallel to serial. It also has single-knob control of cutoff for both filters, and an 'Offset' knob that raises the cutoff of one filter while lowering the cutoff of the other.
This scheme allows a lot of variety, like parallel filters with different cutoffs, a steep 36dB lowpass filter, a wide phaser-ish resonant notch filter, and complex responses that fall somewhere between these.
One possible variation on this idea would be to substitute a second 12dB filter for the 24dB filter, and connect it's HP and LP outputs to a crossfader. This way, instead of 'switching' from LP to notch to HP, you would have smooth variable transitions.
Par-Ser Filter Template1.pch2
Parallel / Serial filter 'buildig block' patch
 Filename:  Par-Ser Filter Template1.pch2
 Filesize:  2.11 KB
 Downloaded:  788 Time(s)
Dave Peck
