selecting 2N5172 NPNs for maximum noise
Page 1 of 1 [2 Posts]
soundforger
PostPosted: Mon Feb 06, 2012 3:13 pm    Post subject: selecting 2N5172 NPNs for maximum noise Reply with quote  Mark this post and the followings unread
In his description of the schematics of the MFOS Soundlab Ultimate, Ray says:
"Test several 2N3904s to find the noisiest one."
and:
"I bought a bunch of 2N5172 NPNs and found that about one in 8 of them stands TALL above the rest as far as noise generation."
How does one measure the noise? Is there a special circuit to test this, like Ray's breadboardcircuit for transistor matching?
fluxmonkey
PostPosted: Mon Feb 06, 2012 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
nothing fancy, just start putting them into the circuit until you find one that puts out a decent level of noise. instead of soldering them in, you could just use test lead clips until you find the one... sometime you have to go thru a dozen or so to find a good one. besides the 5172 and 3904, i've also gotten good results w/ 2n2222s.
www.fluxmonkey.com
Niio1
