 Forum index » Online Music
Beethoven's Moonlight Sonata
Page 1 of 1 [5 Posts]
JovianPyx
Audio files: 224
PostPosted: Mon Feb 06, 2012 9:55 pm    Post subject: Beethoven's Moonlight Sonata Reply with quote  Mark this post and the followings unread
This is from a MIDI file I found that I modified and sequenced to my TriXarp and FM bell synths.
TriXarp is a triple Karplus-Strong harp with a total of 192 strings. Each note of the TriXarp is played with 3 strings, each detuned slightly from the others similar to a piano harp. The FM bell synth is a 16 voice 8 operator FM synth.
Beethoven_Moonlight_Sonata.mp3
 Filename:  Beethoven_Moonlight_Sonata.mp3
 Filesize:  14.23 MB
 Downloaded:  1994 Time(s)
Time flies like a banana.
corruptio optimi pessima
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Feb 06, 2012 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love the fm bell sounds.
How are the 8 operators connected, 4 pairs of carrier/modulator? What ratio and mod index % etc.
I've done a lot of playing with fm and have never come across anything that sounds quite as good.
adambaby
PostPosted: Tue Feb 07, 2012 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know which sound is which, but I'm gobsmacked at just how good two expressive sounds can be in the right context... love it! All you need is some judicious reverb and a trendy remix on the B-side, next thing you know, Gaga is on the phone...
Adam Inglis
A Disco Ate My BABY!
www.adambaby.com
JovianPyx
Audio files: 224
PostPosted: Tue Feb 07, 2012 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
This synth has a fixed algorithm of 4 pairs of carrier and modulator.
Ratios used were 0.50000, 3.00012, 1.50018, and 2.00092. Index is controlled by an ADSR per pair. Index attack is fairly fast and is set a bit differently for each pair.
Thank you Smile
Audio files: 212
PostPosted: Thu Feb 09, 2012 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
wave
