Performance Dumps into Nord Lead 2
Page 1 of 1 [4 Posts]
Baz Mac
PostPosted: Thu Feb 09, 2012 3:35 pm    Post subject: Performance Dumps into Nord Lead 2 Reply with quote  Mark this post and the followings unread
Hi there,
I've searched these forums, the manual, the clavia website etc. and I just can't work out how to dump performance banks to the Nord Lead 2. Not had a problem dumping programs, just performances. I was wanting to try the ones on the Clavia website (http://www.clavia.se/downloads/sounds/nordlead2.htm), but Nordgen, which I used for dumping the programs doesn't seem to do so for performances.
It must be possible if they have them on the Clavia website, right? How is it done?
Thank you in advance.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 10, 2012 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
A Dump upload has to be done using a PCMCIA card, if you are on a Lead2. If you are on a Lead2X you just need the file and use a tool which is able to upload (download to the synth) Performances, like Borne's SendMidi. You can use SendMid to without a PCMCIA card, but you can't save into the memory...
The synth is already 16 years on the market!
Wout
Baz Mac
PostPosted: Fri Feb 10, 2012 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Wouth!
The Borne program worked where others failed.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 10, 2012 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Woops! You're quick Very Happy
Wout
