  bingsatellites Mostly Ambient
Getting started with LiSa and multiple samples
Page 1 of 1 [12 Posts]
Inventor
Audio files: 256
PostPosted: Mon Feb 13, 2012 9:17 am    Post subject: Getting started with LiSa and multiple samples Reply with quote  Mark this post and the followings unread
Hi, I am working on a motion controlled sample playback program set and I want to load in many samples and play them each back with multiple voices. Do I need a separate Lisa entity for each sample? I'm having trouble getting started here...
Les
Audio files: 211
G2 patch files: 92
PostPosted: Mon Feb 13, 2012 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could put seveal samples in sequence in Lisa's buffer if you want, and set the start point to whatever sample you want to play. I personally think it's easier to just as many Lisas as I want. The tricky bit is getting the samples into Lisa, the are examples to follow for that.
Inventor
Audio files: 256
PostPosted: Mon Feb 13, 2012 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
gotcha, thanks Stefan. Will do like that.
Les
Inventor
Audio files: 256
PostPosted: Tue Feb 14, 2012 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, here is what I have so far. Don't download it because you can't run it without the samples and a Gyration Air Mouse - but you can look at the code. This program has only eight samples of four seconds each, yet it totally thrashes the cpu on my mac mini. Granted, the computer is three years old and ready for replacement, however it should be able to handle this. Does anyone have any idea what I am doing wrong here?
Thanks,
Les
OSC Receiver Drums 1.ck
Osc receiver for drum samples
 Filename:  OSC Receiver Drums 1.ck
 Filesize:  2.9 KB
 Downloaded:  91 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Tue Feb 14, 2012 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the program looks ok. Your Mac should be able to run it fine.
Are you getting a crash, or just some kind of lockup?
Have you tried logging, just to make sure where it crashes? The obvious suspect is the for loop that copies data into Lisa I guess - it will take a while to copy 8*4*44100 samples, and ChucK's clock might run out of sync too much.
I know that this is the way it's done in the tutorials, but maybe having a big locking loop like this makes ChucK feel bad. One trick might be to add a
1::samp => now;
every 10000 iterations or so, to allow the clock to run.
Another solution could be to do it the simplistic way, by chuck each SndBuf to its Lisa instance, and record the sound using Lisa's record function at the start of the program. This means that you need a 4 second program "boot" time (or whatever your longest sample is).
Inventor
Audio files: 256
PostPosted: Tue Feb 14, 2012 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
it does crash occasionally but the main issue is that if too many samples are playing, it will cut off audio and stop the radio broadcast too. Just too much cpu is all because i tried it with 1 second samples and no problem.
so i figure the solution is shorter samples which can be done with the drums, and longer gesture recognition for things like the 30 second thunder samples. that should do it. ty for looking at the code.
Les
GrandJu
PostPosted: Tue Feb 14, 2012 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Les,
I don't understand why you are using Lisa. But Maybe I don't get the real purpose of your script Laughing
Just using SndBuf (without Lisa) may save some memory and CPU.
Something like (not tested):
Code:
for (0=>int i; i<numBins; i++)
   buf[i]=> dac;
  // Put each buf at end to avoid starting
    buf[i].samples()=> buf[i].pos;
function void playSound(int sel)
    // get next voice
    0 => buf[sel].pos;
    2. => buf[sel].rate;
    //hang on until it's done...
    buf[sel].length  => now;
Ju
Inventor
Audio files: 256
PostPosted: Tue Feb 14, 2012 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ju,
I am using LiSa because it allows me to have multiple voices per sample so that if someone strikes the same sample twice quickly, both samples will play. That is why.
Les
GrandJu
PostPosted: Wed Feb 15, 2012 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I understand now Very Happy
It's true that with my proposal, you might have some kind of freeze effect if samples are trigged several times quickly.
I have to experiment Lisa on my side to know it.
Have Fun!
Ju
Inventor
Audio files: 256
PostPosted: Wed Feb 15, 2012 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ju, thank you for your input and your interest. How long have you been a ChucKist?
Les
GrandJu
PostPosted: Thu Feb 16, 2012 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I play with ChucK since january 2010. And I learn electronic music this way!
It's fantastic Very Happy
Ju
Inventor
Audio files: 256
PostPosted: Thu Feb 16, 2012 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I agree, I did the exact same thing, starting in October of 2007. But it does not matter how long you have been a ChucKist, as long as you wield the mighty power of ChucK! Haha!
Les
Niio1
