  bingsatellites Mostly Ambient
What´s wrong?
Page 1 of 1 [5 Posts]
purpurkatten
PostPosted: Thu Feb 16, 2012 12:52 pm    Post subject: What´s wrong? Reply with quote  Mark this post and the followings unread
Lately, every time I play an A6-preset, the synth suddenly loads the ENV3 page in the small screen. I don´t touch any knob or anyting, I just play the keys. At the same time, the sound loses its sustain and sound very dry and boring.
Very disturbing. This way I can´t play the synth normally anymore.
I tried a hard reset. It didn´t work.
Any clues?
Thankful for help
All A6 programming pros, don´t hesitate to put together your best patches and make them available on the Internet! If you´d like to charge a reasonable fee for others to download them, that is fine by me! The more attention and patches and community for the Andromeda, the better!
sunny pedaal
Audio files: 12
PostPosted: Fri Feb 17, 2012 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
try if one of the knobs.pots of env3 "sticks/ has some dirt in it.
simply see if pressing one of the knobs changes the screen.
there is also an test mode for all knobs, see test/ softbuttons in manual to find out the exactnummer to push while starting up.
i always have a dustcover over the a6 when notis use , and from time to time, move a vacuumcleaner over the knobs and pots to remove dirtpieces. ( have a nylonstocking fit over the tube though to prvent small parts beinig suck up to..)
purpurkatten
PostPosted: Fri Feb 17, 2012 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip, I will try that.
I too always have a blanket covering the synth at all times when not played.
purpurkatten
PostPosted: Tue Feb 21, 2012 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m a bit embarrassed, I should have thought about it myself, of course, but anyway, your tip seem to have worked!
Thanks! well done
sunny pedaal
Audio files: 12
PostPosted: Tue Feb 21, 2012 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
fine, nice to hear.
Niio1
