 Forum index » Instruments and Equipment » Kyma
Keeping Kyma Alive
Page 5 of 6 [128 Posts]
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, thanks for the copy, looked fine, and thanks for sending that to them!
BobTheDog
PostPosted: Wed Aug 08, 2012 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok good, Just checking it went out ok.
Lets see what they say.....
My guess is its some resource leak in their audio/firewire code on the pacarana.
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
There are multiple issues I think, with a USB interface I run in trouble too, just seems to last a bit longer overall ... but there is some random component too, and my gut feeling is that OSC is not handled correctly either.
BobTheDog
PostPosted: Wed Aug 08, 2012 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
An interesting test may be to disable all audio channels apart from two and see if it lasts longer on the Konnekt.
Was the USB interface a two channel one?
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it was 2 ch, still is Wink
Interesting way to look at it ... I'll reconnect the t.c. again this evening ... how would i disable channels on it? In kyma, or would i need re-install its driver?
I don't really want to use the USB one - it's my zoom h2 thingie and want to take that one with me for when I run into interesting sounds to sample.
BobTheDog
PostPosted: Wed Aug 08, 2012 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried it in Kyma DSP Status->Configure
I turned all input channels off and all outputs apart from 1&2 off, The I/O % on the front panel just seems the same evern after a restart.
Might be worth a punt though.
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok restarted with tc connected and nothing else changed. Turned all inputs off, and kept two outputs enabled.
4 minutes .. counting.
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Previous setup had run for about 140 hours ... not a week ... what I did see however that one DSP was running at 43% and I/O was running at about 20%.
I/O is now 94% .. 99% and DSP 4 is at 37%, the others at 1%.
BobTheDog
PostPosted: Wed Aug 08, 2012 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow that I/O is high!
Mine with all channels going varied wildly between 20-77%.
My DSP 4 was always at 44%.
What I/O delay have you got it going at, mine is at 14ms.
Just changed I/O dalay to 4.5ms and I get a lower I/O %, seems to stick pretty solidly at 26% with the odd leap up to 75%.
I wonder what that figure signifies!
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
10 ms
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
But erm .. no idea what it means, I;ve reported that number to symbolic sound one time .. got no comments on that.
edit (the I/O percentage).
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 08, 2012 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
<bang>
2 hours 48 minutes and 57 seconds
Pacarana is not responding, Unhandled Firewire bus reset or Firewire error (22)
lemme reload ... cursor turns into watch ... please turn on or connect connect your Kyma signal processor ... ok ... pacarana still shows 37% for DSP 4 I/O 36% now ... ok .. pull firewire cables ... put them back ... hit ok again ... watch ok .. its back it seems ... saving debug logs ... I/O back to 46 ... 88% DSPs all at 1% .. staring patch again ... and it runs ...
ok, sent out the deb ug log.
BobTheDog
PostPosted: Wed Aug 08, 2012 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well my idea about the audio channels was a no go then.
Its interesting that it restarts the same as mine if you pull the cables.
I wonder if your log will have the "logical unit reset" like mine did....
Audio files: 116
G2 patch files: 317
PostPosted: Thu Aug 09, 2012 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It apparently did.
When I left home this morning for work the thing was still running BTW.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Aug 09, 2012 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
After checking home stream - it still runs.
Audio files: 116
G2 patch files: 317
PostPosted: Wed Aug 22, 2012 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
The symbolic sound folks found an issue and made a fix for that ... the current patch has been running now for 65 hours with the t.c. electronic ... this is looking good!
Going to let it run a bit more and then will plug in some OSC stuff again.
BobTheDog
PostPosted: Wed Aug 22, 2012 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff, if yours fails again I can do some more testing......
Muied Lumens
Audio files: 204
PostPosted: Wed Aug 22, 2012 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
It's alive! Laughing
Muied Lumens Base Star
BobTheDog
PostPosted: Wed Aug 22, 2012 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
We expect great things from you now Jan Smile
I want to start using mine more, seems to have been gathering too much dust lately.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Aug 23, 2012 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I just survived a power dip that made me have to restart adsl modem, ethernet switch, local server and a laptop's ethernet connection Shocked
almost 90 hours now Cool
BobTheDog
PostPosted: Thu Aug 23, 2012 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
It will outlast us all now!
cebec
G2 patch files: 31
PostPosted: Thu Aug 23, 2012 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear this!
http://www.soundcloud.com/cebec
Audio files: 116
G2 patch files: 317
PostPosted: Thu Aug 23, 2012 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Where I wrote "I" I meant "It" BTW.
Audio files: 116
G2 patch files: 317
PostPosted: Fri Aug 24, 2012 8:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
To have some OSC again I've plugged the ethernet cable in after 116 hours or so without crashing ... been stable for 12 hours now in that new situation, and counting.
Thank you very much Andy for stepping in, it was your crash report that pointed to the bug fix Smile
Looks like solved to me Cool
(knocking wood, we need a knock on wood emotismile thingie)
BobTheDog
PostPosted: Sat Aug 25, 2012 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Really glad to hear that Smile
