  Twyndyllyngs Live - back after 3 weeks Chez Mosc
TL082 based 1KHz Sine/Cosine Wave Oscillator schematic
Page 1 of 1 [4 Posts]
Sinusoid
PostPosted: Thu Mar 15, 2012 9:17 am    Post subject:  TL082 based 1KHz Sine/Cosine Wave Oscillator schematic
Subject description: Please help
Hello guys,
I am a total noob, just wanted to straight that out from very beginning, so please don't be too harsh on me.
Really need your help as I have to build a 1Khz oscillator which should be based on TL082 and it has to give out the sine and cosine wave-forms
I have found a schematic online:
http://www.eleccircuit.com/sinecosine-wave-oscillator-by-tl082/
but I have no idea how to get a 1Khz frequency there.
Could you please help me out?
Will really appreciate any help.
Thank you
PostPosted: Fri Mar 16, 2012 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't help you, just want to point out that this kind of question might work better in the DIY forum. Smile
Mongo1
PostPosted: Fri Mar 16, 2012 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi - I found a website that has that circuit plus the formula to determine the frequency -
http://www.massmind.org/images/www/hobby_elec/e_ckt20.htm
You'll just have to work the formula backwards a bit, and you should be good.
Note that in the example, he's using .001 uF caps, and 15K resistors to get 10.585 Khz. I think if you just bumped your caps up to be .01 uF, you'd probably be in the ballpark (about 1060). You could replace the 15K resistors with something like 12K resistors in series with a dual 5K pot so you could adjust the frequency to an exact point if you wanted to.
Gary
Sinusoid
PostPosted: Sat Mar 17, 2012 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Gary
Thanks Gary,
Really appreciate it. That's what I was looking for.
Will try to build it now =)
