Comprehensive Octave-Phase-Coherent Oscillator Suite
Page 1 of 1 [6 Posts]
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Thu Apr 05, 2012 1:20 pm    Post subject: Comprehensive Octave-Phase-Coherent Oscillator Suite
Subject description: All classic waveshapes available; Lowest possible DSP usage; Good sound;
These algorithms are a consolidation of new patching techniques I've been exploring. They are intended as building blocks for patches that emulate divide-down-type instruments like classic string machines or transistor organs. I already posted an attempt some time ago, but these ones are far more elegant, use about half the DSP load and sound better too.
The circuits generate octave-phase-coherent oscillators over a keyboard range of 5+ octaves, starting at C2. All classic waveforms (triangle, sawtooth, pulse) are available, either separately (more economic) or simultaneously. Good sound quality and low DSP cost in the voice area were highest priority. Hence everything that needs to be calculated only once has been moved to the FX area, where stuff is piped back to the voices via two interslot busses.
EDIT: I found another all-too-obvious improvement, bringing down the DSP usage even more. All patches have been optimised and re-uploaded. Here are the new stats:
Voice Area DSP usage (cycle/mem) for the different oscillator circuits (bare circuits without any extras):
Triangle: 13/11.7
Sawtooth: 13.7/13.3
Square/Tri: 14.4/13.3 (square is derived from triangle through shaping)
Saw/Pulse/Tri: 18.6/15.6
All waveforms are available simultaneously on the multi-wave versions. Cool
arrow The FX area contains the whole osc driver engine and uses 30.6/43.8. It generates 64 simultaneous octave-phase-coherent oscillator drivers and squeezes them through two interslot busses. shakng2
If, due to this, you run out of DSP in the FX section, just create a performance. Put the osc driver into the FX section of any free slot and use another slot for your patch, thus having a full free FX section for your design. Just remember that interslot buss 1 and 2 are used.
arrow There's an optional vibrato implemented (move modwheel), just to show how to do this.
arrow I used a constant module with accurately tweaked keyboard morph to obtain note information, rather than using the wasteful keyboard module.
arrow Note to the square wave: this is derived from the triangle wave through hard-clipping and fierce feedback. The feedback is way above unity gain
so the waveform flanks are steep enough to generate the characteristic buzzy high frequencies. This works well for square. Variable pulse width is also possible by mixing a DC offset into the feedback loop. However the feedback then has to be reduced to unity gain, otherwise the waveshaper will clamp. So PWM is available but will sound a bit less brilliant. (see example patch)
These are the absolute lowest DSP counts I could muster for such an actually quite complex task. I hope they are low enough to be useful. It was an exercise in super-efficient patching while maintaining a good sound quality. There's only a slight tad of aliasing in the square wave at the uppermost notes, which can be dealt with by lowering the shaper feedback (eg. by subtle negative keyboard morph).
"May the problem of octave-phase-coherency be forever banished!" Let us pray
OctPhCohTriOscTK.pch2
Octave-phase-coherent triangle oscillator building block; see thread for info;
 Filename:  OctPhCohTriOscTK.pch2
 Filesize:  4.35 KB
 Downloaded:  145 Time(s)
OctPhCohSawOscTK.pch2
Octave-phase-coherent sawtooth oscillator building block; see thread for info;
 Filename:  OctPhCohSawOscTK.pch2
 Filesize:  4.48 KB
 Downloaded:  144 Time(s)
OctPhCohSqrOscTK.pch2
Octave-phase-coherent tri/square oscillator building block; see thread for info;
 Filename:  OctPhCohSqrOscTK.pch2
 Filesize:  4.58 KB
OctPhCohPWMOscTK.pch2
Demonstration of PWM on the octave-phase-coherent tri/pulse oscillator building block; see thread for info;
 Filename:  OctPhCohPWMOscTK.pch2
 Filesize:  4.65 KB
 Downloaded:  138 Time(s)
OctPhCohMulOscTK.pch2
Octave-phase-coherent tri/square/sawtooth multi-output oscillator building block; see thread for info;
 Filename:  OctPhCohMulOscTK.pch2
 Filesize:  4.81 KB
 Downloaded:  133 Time(s)
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Thu Apr 05, 2012 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found another all-too-obvious improvement, bringing down the DSP usage even more. All patches above have been optimised and re-uploaded.
Here's another application. Some divide-down instruments featured 2 master oscillators in the top octave which could be detuned. Here's a octave-phase-coherent dual-saw oscillator that does this.
The global detune knob is in the FX section.
Only 20.4/18.8 DSP for two oscillators.
OPCDualSawOsc_TK.pch2
Octave-phase-coherent dual-sawtooth oscillator; see thread for info.
 Filename:  OPCDualSawOsc_TK.pch2
 Filesize:  5.1 KB
 Downloaded:  163 Time(s)
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Apr 06, 2012 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Seems that you are very inspired lately Very Happy Thanks for the blocks!
They don't work in the demo, I'll try them at home.
Albert
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Fri Apr 06, 2012 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Easter holidays... Rolling Eyes Laughing
Don't expect much of these patches, they just produce bland waveforms. Laughing But octave-coherent waveforms. If you're into patching Solinas and Polymoogs etc., they might be interesting. Otherwise probably not. Laughing
I'm making some fascinating discoveries concerning modulo operations, it's addictive. This is simply byproduct of that.
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Apr 06, 2012 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you remember your trick using phase filter to fatten the waveforms?
Would it be possible to do it in the waveform building block in the FX area?
Albert
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Fri Apr 06, 2012 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
This design doesn't generate the waveform in the FX area. It is directly derived from the demultiplexed and modulo-linearly reconstructed oscillator driver (a trivial audiorate sawtooth) through waveshaping. This is the most economical way, and also uses up only 2 interslot busses.
Of course it is perfectly possible to combine the octave-phase-coherency technique with anti-aliased user-definable waveforms. The high poly organ patch does exactly this, the user-definable waveform in this case being additively generated by sine waves corresponding to the drawbar footages and levels. It's almost like cheating. Laughing
