Welding glasses frames
Page 1 of 1 [3 Posts]
audiodef
Audio files: 27
PostPosted: Wed Apr 18, 2012 10:30 am    Post subject: Welding glasses frames Reply with quote  Mark this post and the followings unread
I figured since a lot of you guys are DIY hardware freekz, you might have some ideas.
I just got new glasses frames. As some of you know, I wear hearing aids. Getting new frames is a challenge because most modern frames in conjunction with hearing aids are uncomfortable to some degree.
I want to replace the temple tips with cables. A local frame mender said he wouldn't do it for these frames (although I left him another frame to convert to cables - those will be my sunglasses/outdoor glasses with polarized lenses).
What would it take to snip off the temple tips from sturdy metal frame temples and weld cables on?
Audiodef
Synthetronica
Gentoo Studio
DES
Audio files: 6
PostPosted: Thu Apr 19, 2012 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Metal frames I assume? ( there is a product called plastic weld for, you guessed it, plastic).
You could try silver solder. Most jewlers that do repairs will have it and might actually do it for you. Needs a higher temp then regular solder.
www.davesneed.com
www.myspace.com/desneed
audiodef
Audio files: 27
PostPosted: Sat Apr 21, 2012 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm, I never thought to ask jewelers. Maybe I'll ask a few in my area.
Audiodef
Synthetronica
Gentoo Studio
Niio1
