Welding glasses frames
Page 1 of 1 [3 Posts]
audiodef
Audio files: 42
PostPosted: Wed Apr 18, 2012 10:30 am    Post subject: Welding glasses frames Reply with quote  Mark this post and the followings unread
I figured since a lot of you guys are DIY hardware freekz, you might have some ideas.
I just got new glasses frames. As some of you know, I wear hearing aids. Getting new frames is a challenge because most modern frames in conjunction with hearing aids are uncomfortable to some degree.
I want to replace the temple tips with cables. A local frame mender said he wouldn't do it for these frames (although I left him another frame to convert to cables - those will be my sunglasses/outdoor glasses with polarized lenses).
What would it take to snip off the temple tips from sturdy metal frame temples and weld cables on?
Audiodef
Gentoo Studio
DES
PostPosted: Thu Apr 19, 2012 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Metal frames I assume? ( there is a product called plastic weld for, you guessed it, plastic).
You could try silver solder. Most jewlers that do repairs will have it and might actually do it for you. Needs a higher temp then regular solder.
www.davesneed.com
audiodef
Audio files: 42
PostPosted: Sat Apr 21, 2012 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm, I never thought to ask jewelers. Maybe I'll ask a few in my area.
Audiodef
Gentoo Studio
