Nord Lead Buttons
Page 1 of 1 [4 Posts]
ZeHa
PostPosted: Wed Apr 25, 2012 3:36 pm    Post subject: Nord Lead Buttons Reply with quote  Mark this post and the followings unread
Hello,
has anyone here tried to remove buttons from the Nord Lead (e.g. the "Distortion" button etc)? I'm asking because I'm thinking about re-painting some of these button caps, like the 4 parts buttons and the "trigger" button with glow-in-the-dark color or something like that, for easier access when using on a dark stage etc...
And I don't want to do this if I can break something. Are they easily going off like buttons from a computer keyboard? And is it possible to re-order them if I should feel like putting the Nord Lead back to its original state?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 26, 2012 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
If you do it carefully, it is a normal job.
Open the synth, detach the Panel and lift the caps carefully.
Watch out the LED's when attach the Panel again.
At http://www.syntaur.com/nord.html you can find spare parts, but you have to ask them if the caps are available.
Wout
ZeHa
PostPosted: Thu Apr 26, 2012 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, so it's not possible to remove the caps without opening the whole Synthesizer?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Apr 26, 2012 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, sometimes, without any logical reason, it happens spontaneously.
You can try, but I have done it with the Panel board detached. One can easier plop the button off Smile
Wout
Niio1
