Ruby amp 10K pot only working in a small range
Page 1 of 1 [2 Posts]
spadger
PostPosted: Tue May 01, 2012 6:37 am    Post subject: Ruby amp 10K pot only working in a small range Reply with quote  Mark this post and the followings unread
Like title says, I've built two of these now and the same problem, The 10k pot works for only a small range. It will go full volume, but it only take a small increase on the pot, after that the sound just distorts and then goes, so i have to turn it back down to a small amount again for the sound to work again. While i have the volume pot in this small range, the 1k gain works full range ok. I'm kind of baffled because i first built the circuit on a breadboard using the schematic, and i have no problems reading schematics. The sound was working great, both pots using the full sweep range without cutting out.
numbertalk
PostPosted: Tue May 08, 2012 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried asking the guy at runoffgroove.com? He was responsive the time or 2 I contacted him when I built mine years ago.
