ADSR v.2 GATE PROBLEM
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
roglok
PostPosted: Sat Jun 23, 2012 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Therefore, invert D5 and the LED and you will obtain a normal behaviour for the LED.
Are you sure about that, Yves? The LED driver from the old layout works just fine here...
yusynth
PostPosted: Sat Jun 23, 2012 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I will check that thoroughly tomorrow and I will return to you.
Yves
yusynth
PostPosted: Sun Jun 24, 2012 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I confirm the correction for the V2 version. The V1 (old version) is not concerned)
Yves
Benjamin AM
PostPosted: Mon Jun 25, 2012 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Yves,
I flipped the diode and the LED on one of my modules and now I get no illumination from the LED. Am I missing something?
Thanks, -Benjamin
roglok
PostPosted: Wed Jun 27, 2012 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Tried it too, but doesn't work for me either. I reverted to the old configuration.
If it ain't broke, don't fix it cyclops
EDIT: I am using the V2 layout with some mods/fixes outlined in a German forum http://www.sequencer.de/synthesizer/topic-54153.html. Those changes shouldn't affect the LED driver functionality though...
yusynth
PostPosted: Wed Jun 27, 2012 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
If your ADSR works don't fix it Wink. I may have a different PCB on my prototype that the one published on my site and this would explain the confusion.
Yves
Yves
