  Antimon Antimon Waves
PropB3 - DIY Hammond organ
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
Spikes
PostPosted: Wed Mar 06, 2013 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hear what you are saying Dan, but I'm trying to reduce the amount of projects I build and just concentrate on making music. So in order to reduce temptation, I'm looking for a pre programmed chip.
Mongo1
PostPosted: Fri Apr 26, 2013 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got an old Hammond X5 that is in pretty dire shape. I keep wondering if I could replace the guts of that old girl with a couple of these. The trick would be figuring out how to deal with the drawbars. I'm not sure if it's even possible.
Gary
Dan Lavin
Audio files: 21
PostPosted: Thu Aug 22, 2013 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I see Parallax has introduced the Propeller Mini (#32150). It should be easy enough to use the new mini with a perfboard, a TDA1543 from ebay and a TS912 to replace the TS914 and a 6N139. You would need to buy or borrow the little Prop Plug USB programmer but this project just got a little easier (and smaller) to make.
Synth DIY since 1977!
grenert
PostPosted: Wed Oct 15, 2014 10:30 pm    Post subject:   Reply with quote  Mark this post and the followings unread
A bump for a great sounding instrument.
Using the Propeller Quickstart board it was a pretty easy weekend project. It eliminates the need for memory and power supply. All you need to add is the optocoupler, DAC and filter.
I have been so happy with the sound of mine! So much fun to hear the Leslie speakers speed up and slow down with the mod wheel. Cool
