[SOLVED] ADSR without trigger input (i.e. using gate only)
Page 1 of 1 [5 Posts]
reve
PostPosted: Sat May 19, 2012 2:47 pm    Post subject: [SOLVED] ADSR without trigger input (i.e. using gate only) Reply with quote  Mark this post and the followings unread
Hey guys.
So I built a couple of Ray's ADSR boards and am not quite seeing how to wire them without using the trigger input.
If I leave the trigger input floating it doesn't work.
If I tie the trigger input to ground it works as expected in "long" mode, but "short" mode makes it work as if I applied a trigger -- it just runs through the attack and release cycle.
Should I tie the trigger in to +V? Normal it to gate? What's my best approach?
- r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik
forshee
PostPosted: Mon May 21, 2012 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It should just be left floating. It's not normaled to anything in the schematic. I'd check your wiring I don't see how the short and long switch could change anything as it just adds a cap in parallel with the other timing cap.
reve
PostPosted: Tue May 22, 2012 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
forshee wrote:
It should just be left floating. ... I'd check your wiring
Doops. Yes, it was my wiring. Thank you, forshee!
- r. mosquito
forshee
PostPosted: Tue May 22, 2012 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad I could help. What do you think of it? I'm still without a proper ADSR and shopping around.
reve
PostPosted: Wed May 23, 2012 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as prefabbed boards go, I say it's a winner. I did a couple of Yves' ADSR boards which aren't as versatile in the modding department but sport a much lower parts cost. The downside of course is you're etching your own boards -- which I find a huge PITA. I got a couple of the MFOS ADSR kits from Bridechamber as I was feeling even more lazy than usual... so this worked out well for me.
The Tom Wiltshire digital ADSR wins the easiest / fastest prize, though.
- r. mosquito
mps board
