Filter F1 mix
Page 1 of 1 [3 Posts]
scd
PostPosted: Sun May 20, 2012 12:45 pm    Post subject: Filter F1 mix Reply with quote  Mark this post and the followings unread
Does anyone know what the filter F1 mix parameter does? It is hidden in the post filter mix section, and I can not find anything about it in the manual.
It seems to control the post filter mix level of the LP filter but that seems odd: there is already a lowpass filter mix level parameter, including a fysical control pot for it.
Something Completely Different
http://www.synthmusic.info
sunny pedaal
Audio files: 12
PostPosted: Mon May 21, 2012 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
balance between f1 and f2 ?
fishjaco
PostPosted: Thu May 31, 2012 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The individual F1 LP, BP and HP levels are adjusted in relation to each other within Filter 1 as a whole. "F1 Mix" adjusts the level of Filter 1 as a whole (comprised of its BP, HP and LP levels) in relation to the other Post Filter Mix elements (F2 & Pre-Filter).
Did I explain that clearly?
Niio1
