  bingsatellites Mostly Ambient
Saware-angle wave circuit
Page 1 of 1 [15 Posts]
JingleJoe
PostPosted: Fri Jun 01, 2012 10:06 am    Post subject:  Saware-angle wave circuit
Subject description: makes a weird wave from your triangle wave
This circuit makes an unusual waveform which is a combination of saw, triangle and square, hence the name saware-angle Smile
It's function is very simple; when the triangle wave input goes above the CV input, the comparator output goes high and the transistor is turned on. Then the output of the circuit is effectively connected to ground, cutting off the signal. However, only a portion in the middle of the wave is cut off, leaving the saware-angle wave at the output.
The square portion can have it's pulse width modulated by changing the CV input, but as it says on the diagram, the CV changes the amplitude of the output wave. This can be remedied by changing the amplitude of the triangle wave instead Smile
I've been reluctant to share this idea but I don't care what other people think, if you don't like it, I don't care. I think it's a very interesting wave and I've wanted a waveform like this for ages.
 Filesize:  6.79 KB
 Viewed:  2006 Time(s)
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
PostPosted: Sat Jun 02, 2012 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought the technical term for this wave was the "M wave" Smile.
James.
inlifeindeath
PostPosted: Sat Jun 02, 2012 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool! i might have to build this as an LFO.
Any way to remove the low pulse part so it's a continuous l\/ll\/l?
JingleJoe
PostPosted: Sun Jun 03, 2012 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't know if this wave had a name, I think saware-angle is cooler than M wave though Laughing
The low pulse is what gives it the M shape, otherwise it's just a triangle. That is the whole function of this circuit, to add that low pulse to a triangle wave to get an M or saware wave.
Observe, comrades, for I have videolyzed it:
Now with the addition of some control voltage modulation;
PostPosted: Sun Jun 03, 2012 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry JingleJoe, but I was only joking about it being technically called an "M wave". Maybe it is, I don't know, but at least that's what comes to mind when I see it. Of course, more accurately, it's the "M underscore wave" _M_M_M_ hahaha. Smile
I remember producing it before, but not how.
Anyway, cool sounds... carry on!
James.
JingleJoe
PostPosted: Sun Jun 03, 2012 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hahahaha! Laughing
James.
Thanks, I really want to make a VCA to control the triangle input so I can get nicer pwm effects. I tried a simple VC Attenuator, which was easier to conceive than a VC Amplifier, but it didn't work very well.
I am thinking that one could probably put a PNP transistor in the feedback of the standard, simple, op amp inverting amplifier to make an attenuator, without adding any current to the inputs of the op amp from the transistor base because of the way the PNP transistor works. Anyways, ideas to try another day. Smile
EDIT: I just thought; divided feedback! That makes the transistor easier to use as a voltage controlled resistor. When that turns out to be really dodgy I may just resort to an LM13700 Rolling Eyes
frijitz
Audio files: 54
PostPosted: Sun Jun 03, 2012 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks good -- can't imagine why anyone would't like it! I use a similar slicer/dicer in my Wavolver waveshaper. In this one the chopped out segments can be replaced by a variable amplitude folded wave.
http://home.comcast.net/~ijfritz/sy_cir6.htm
An improved version is available from Elby.
Ian
PostPosted: Sun Jun 03, 2012 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I think Richard has something similar in the Deatlahem machine. He has a video where he chops up a triangle wave like that.
Also, is that a pirate shirt you are wearing?
jacobwatters.com
JingleJoe
PostPosted: Sun Jun 03, 2012 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Wow that looks incredible Surprised I'll have to have a proper look at it when I am more awake and can comprehend things.
I'm definitely interested in analogue waveshaping.
I am not familiar with the deathlahem machine, I'd be interested to see how he does it.
Yes. pirat
Audio files: 261
PostPosted: Sun Jun 03, 2012 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
that looks interesting and sounds good too thumleft .
does make me wonder if I can get the same result with
the WaveWiper (shameless promotion Wink)
http://www.acidtrash.com/
PostPosted: Sun Jun 03, 2012 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
After reviewing the video, it is not the same thing. But you can see M-like shapes. He also has an lfo controlling it.
http://www.youtube.com/watch?v=rCFw3F0eVhI
jacobwatters.com
Banjo
PostPosted: Sun Jun 03, 2012 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe, that is fantastic. Another project that I have to add to my list. Can you use the output as a clock source? My guess with my limited knowledge would be that you could. I was thinking that if the signal was used to generate both the audio and a clock, the clock could be fed into a divider which could then be used to break up that signal feeding another oscillator, which would then enhance the pulsating sound. I hope I am explaining myself correctly, as I often confuse myself when I get these ideas.
JingleJoe
PostPosted: Mon Jun 04, 2012 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It's never a bad thing to have ideas Smile the only problem is being able to realize when they will or won't work or be good ideas.
Unfortunately this won't work as a clock for digital/logic circuits, they only accept square waves- 1 or 0, high or low. The saware-angle is an analogue wave with voltages occurring between 5 and 0 or whatever you set the comparator CV to.
However! Connect a scope to the output of the comparator and you will notice 5 volt square-ish signal that could be used with digital things,
also the triangle generator circuit I used was the standard 40106 schmitt oscillator with a bit of extra voltage conditioning to amplify the triangle wave from the cap, and then remove the offset from it too. This means that you can get a square wave from the schmitt oscillator, at the same frequency as the triangle wave, which is compatible with digital circuits Smile
Phew! I feel out of breath after writing all that Laughing
Have no shame my good man, that's very relevant and it is a wonderful device with very interesting results. I have difficulty comprehending how it works though Neutral
interesting, but that seems to be another kettle of fish, I'll need to take a closer look to understand whats going on there, nevertheless, some intriguing waveforms indeed Surprised
Banjo
PostPosted: Mon Jun 04, 2012 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, so the output is analog. Somewhere I recall seeing a way to convert analog to digital, which would then give the results that I am looking for, if my assumption is correct. I have a parts order coming in this afternoon, containing the chips I need to do what I have in mind. That combined with my newly acquired scope will keep me occupied with this for a while. Your ideas and answers to my questions over the past few weeks, have been a real help, and for that I have to say thanks!! Another thing I will need to do is to start posting some video of the results.
JingleJoe
PostPosted: Mon Jun 04, 2012 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem, I am happy to help someone make more weird sounds Wink
Converting the analogue signal to digital probably isn't quite what you're after, I can imagine that might be something like a voltage to frequency converter. You can just take a digital square wave the same frequency as the saware from the initial triangle oscillator to control digital or logic circuits, from which you can get signals to chop it up more.
Look into combining the saware wave with logic signals via a diode OR gate, I find heterodyning signals via gates to be the key to interesting sounds Smile
AmbiphonicDSP
