Moog Sonicsix
Page 1 of 1 [2 Posts]
nikitralala
PostPosted: Wed Jun 27, 2012 4:47 am    Post subject:  Moog Sonicsix
Subject description: my Moog Sonicsix is humming
There was always some hum on my moog but when played the synth was loud enough to cover this. but now the general volume of the soundoutput has fallen to be nearly at the same level as the humming. There is also some kind of crackling and clicking sound that occours from time to time, but very unregulary.
the service manual mentions this problem and it recommends to replace the rectifiers (diodes) the power-regulators. but it mentions the humming only together with a wild modulation of all signals, which is not the problem... the synth itself is fine, all funktions are ok so far.
I was thinking of replacing the powertransformer (the light of the power swith is always slightly flickering) and the two big elko-condensers, they are nearly 40 years old now...
somebody has a better idea or a hint.
in the moment I check for loose connections...
thanks in advance *niki
area of power
 Filesize:  75.58 KB
 Viewed:  35 Time(s)
 Filesize:  75.58 KB
 Viewed:  35 Time(s)
EdisonRex
Audio files: 168
PostPosted: Thu Jun 28, 2012 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I should think you would not need to replace the transformer. Probably all you need to do is replace the two capacitors. Indeed, 40 year old electrolytics have probably seen better days.
Garret: It's so retro.
