Testing MIDI IN
Page 1 of 1 [3 Posts]
Audio files: 151
PostPosted: Tue Jul 03, 2012 6:45 pm    Post subject: Testing MIDI IN Reply with quote  Mark this post and the followings unread
While exploring my arduino last summer, I wrote a little sketch to test whether or not I was correctly receiving midi in by echoing that data to the console in the arduino's programming environment. I haven't tested it this year, but it should help others do the same.
I used the Arduino Mega 2560, which has 4 serial I/O ports. Also, the pins might be different from other arduinos.
Code:
 MIDI IN test
 This sketch is an attempt to read midi in and display it.
 This is one step in the process of creating an arduino-based midi router/processor/arpeggiator.
 started 05 Aug 2011
 modified
 by Dr. Steve [aka MusicMan11712]
 // MIDI IN Buffer [as an array]
int MidiDataBuffer [256];
 // Buffer Pointers [as indexes]
unsigned char WritePointer = 0;
unsigned char ReadPointer = 0;
byte WP = 0;
byte RP = 0;
 // Incoming Data
int IncomingByte = 0;         // incoming serial byte
 // SETUP
void setup() {
  //  Set MIDI baud rate:
  Serial1.begin(31250);
  Serial.begin(9600);
  // Clear MidiDataBuffer and reset write/read pointers
  for (int n=0; n<256> 0) {
    // get incoming byte:
    IncomingByte = Serial1.read();
   Serial.println (IncomingByte,HEX);
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.println("0,0,0");   // send an initial string
    delay(300);
PostPosted: Tue Jul 03, 2012 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Mega (or some model with multiple serial ports) is really your best bet here for doing MIDI development. I did a lot of work with an uno equivalent (started out as the Mintduino breadboard kit, and ended up soldered into a small protoboard), and i beat my head on MIDI stuff until I got the Mega.
Some of my experiences got written up here:
http://electro-music.com/forum/topic-52722.html
Audio files: 151
PostPosted: Wed Jul 04, 2012 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for chiming in on this and for posting the link to the thread with your comments--useful info there. I realized after I posted the midi in test code that it wouldn't work on a single UART Arduino since midi needs one serial connection and communication with the serial monitor needs another. (I chose the Mega 2560 specifically because it had 4 UARTs.)
Like you, for midi I/O I used an old joystick to midi cable. I didn't take it apart, though.
Steve
