  bingsatellites Mostly Ambient
Triggering drum patches from another computer..
Page 1 of 1 [6 Posts]
wheely
PostPosted: Sun Jul 08, 2012 7:30 am    Post subject: Triggering drum patches from another computer.. Reply with quote  Mark this post and the followings unread
Im trying to send GM Drum midi to the G2 from ableton on another computer.
Ive loaded a drum patch with various drum modules, deleted the sequencers, and added the midi input module that allows you to select what midi note is coming in, i.e C1 kick, D1 Snare etc. When i hook each midi module to each drum module and select the correct note, all i get is the same module playing all the midi notes...?? can anyone give me some advice please.
chars.
wheely
PostPosted: Sun Jul 08, 2012 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
or even better still.... post me an example of a working template.. Smile
General Elektrick
PostPosted: Sun Jul 08, 2012 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, are you using the NoteZone Module for this? If not check the help section of this module and see the application example below the module description...
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Roland Kuit
G2 patch files: 124
PostPosted: Mon Jul 09, 2012 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
You need a bunch MIDI Note Receive modules.
The Midi Note Receive module reads incoming midi notes, velocity and gate signals. For every drum module you need a separate Note Receive module.
Trig out of this module to trig in of a drum module. Velocity out to Velocity in of the drum module. If you have created your own drum stuff, Trig and velocity out to the Envelope Generators in. With Note, you select which GM trig you need.
Roland Kuit
http://rolandkuit.com/
wheely
PostPosted: Mon Jul 09, 2012 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes Roland, This is what i tried before, Midi note receive, take the yellow gate out to the yellow trig on drum module.. and vel out to vel in on drum module. but i get nothing. Sad so i loaded a simple 808 kit and did the same, and its working now! so it must have been something in the patch i was using before..?? But, im sending out on C1, D1, E1 in ableton, yet in the note receive module, it wants it to be C2, D2, E2... its not a problem tho.
cheers!
wheely
PostPosted: Mon Jul 09, 2012 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ general elektrik - i have not tried that module yet, will have a look. thanks Smile
Niio1
