Voltage Controlled Crossfader/VCA
Page 1 of 1 [4 Posts]
Thomas_Henry
PostPosted: Mon Aug 06, 2012 7:57 pm    Post subject: Voltage Controlled Crossfader/VCA
Subject description: Another circuit for your consideration
Hi Gang,
As promised, here is another circuit for you to play with. It can be used either as a voltage controlled crossfader or as an ordinary VCA. I hit upon this when finally realizing something that was in front of me all the time---the control currents though the voltage-to-current converter are symmetric yet opposite. It's an obvious idea once you see it and has probably been used before. But I was glad to stumble upon it.
Null out the DC thumps in the usual way. (Turn the audio inputs down, then apply a 0 to +5V square wave to the CV input.)
The usual legalese applies. Feel free to use this for personal applications but don't copy, or produce commercially. Anyone wanting to do a non-commercial PCB for EM users please contact me first.
Have fun!
Thomas Henry
Schematic --- Sheet 1
 Filesize:  53.57 KB
 Viewed:  230 Time(s)
Schematic --- Sheet 2
 Filesize:  77.2 KB
 Viewed:  200 Time(s)
Parts List
 Filesize:  51.65 KB
 Viewed:  143 Time(s)
PostPosted: Tue Aug 07, 2012 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks fun Mr Henry! Cheers! Very Happy
ACHTUNG!
inlifeindeath
PostPosted: Wed Aug 08, 2012 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
can't wait to try out the new designs thomas! thanks as always for your work!
widdly
PostPosted: Wed Nov 07, 2012 8:39 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks for another great design Thomas.
I built it this afternoon on perf board and it works very nicely. Like the other TH designs I've built, the input ranges on all the controls are tuned perfectly.
emSynth
