1v keyboard issue or not
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
aletropot
PostPosted: Thu Aug 16, 2012 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
U5 chip changed. Same problem...
The Q2 (from diagram) is acting good?
Audio files: 278
PostPosted: Thu Aug 16, 2012 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I think Q2 / Q3 is fine, but that there is too much load on C19 for some reason.
aletropot
PostPosted: Thu Aug 16, 2012 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tomorrow i will take the U3 and check the voltage received.
Im not sure, but i guess when i check with the scope, the c19 pulse was high (the "ground" was higher than 0V)...
If true, what is the problem?
Audio files: 278
PostPosted: Thu Aug 16, 2012 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe write down some voltages and times too then tomorrow Wink
aletropot
PostPosted: Fri Aug 17, 2012 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
C19 without U3 chip its giving me 0V. When a key its pressed, i got the same pulse(same as diagram)...
I found in my notes and i forgot to mention that. In Q2 diagram, the value for key released its negative and when pressed 0V. the same as Q3-G. Dont know if this good or normal...
Audio files: 278
PostPosted: Fri Aug 17, 2012 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, then it is not U3 causing the leakage ... then there is only one thing remaining ... there is a short on the PCB around C19 ... and if not ... I must give up I'm afraid ....
The rest looks all normal to me.
aletropot
PostPosted: Fri Aug 17, 2012 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
SC around c19 or around U3? because till U3-10 everything work well.
I will check better this area...
aletropot
PostPosted: Wed Aug 22, 2012 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
After check everything couldn't find anything. Any suggestion?
Mongo1
PostPosted: Thu Aug 23, 2012 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I built mine I had EXACTLY the same symptoms. Try replacing the S&H cap. Those mylar guys are very easy to destroy when you solder them in. The way around it is to hook an alligator clip between the device body and the solder joint to dissipate the heat.
Gary
aletropot
PostPosted: Thu Aug 23, 2012 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mongo,
I replace 3 times. the first one without the alligator clips, the second one i forgot to use in one side, but the 3rd i used in both sides... I think i dont have nothing to lose and solder one more time... or just use alligator jumpers to see if this solve my problem.
Time to check.....
aletropot
PostPosted: Thu Aug 23, 2012 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing....
I test with more 2 styroflex caps. its hard to believe they are not working...
Can i change for another kind of caps, just to see if the voltage its draining from there?
