Works with ints, but not floats.
Page 1 of 1 [3 Posts]
Khepri
PostPosted: Sun Aug 12, 2012 5:12 pm    Post subject: Works with ints, but not floats.
Subject description: Stack overflow when using != operator
Hi, all. It's been quite a while since I've looked at ChucK (not because of lack of interest.) Now that I'm back at it, a lot of things seem a bit easier to understand.
My question:
I'm wondering why this *will* work with float variables when I use '<'
(less than), but not when I use '!=' (not equal). However it -does- work fine when the variables are int, instead of float.
// Increase value of 'current' by 0.1, until it reaches 1.0
float current;
0.0 => current;
<<<current>>>;
change (1, 0.1 );
fun void change (float target, float amount)
if( current != target )
(current + amount) => current;
<<<current>>>;
change(1, 0.1);
With the code above, the value of "current" does reach exactly the "target" of 1.0000, but it continues past it, to 170.7, and I get a stack overflow error message. As I said, it works as I expect it to with integers or using '<' operator { if(current < target) . . . .
Don't fear mistakes. There are none.
- Miles Davis
Audio files: 116
G2 patch files: 317
PostPosted: Sun Aug 12, 2012 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Such is the nature of floats ... while 1.000000 may seem exact it is in fact a rounded representation of the actual underlying number .. the number could have been 0.9999999999999 when displayed with more digits ... when comparing floats you can not use an exact match but use some sort of "nearly equal" function.
Khepri
PostPosted: Sun Aug 12, 2012 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah - ok. Got it. Thanks, Jan.
Funny, how we usually tend to "believe" what a computer "says." When I see "1.000000 :(float)" come up in the console monitor, I'll be suspicious from now on Smile
- Miles Davis
