  bingsatellites Mostly Ambient
G2X (OS1.62) keeps resetting after power up.
Page 1 of 1 [13 Posts]
homers
PostPosted: Mon Sep 03, 2012 4:01 pm    Post subject:  G2X (OS1.62) keeps resetting after power up. Reply with quote  Mark this post and the followings unread
My G2X (OS 1.62, no PC attached, initial patches which came with 1.62) keeps resetting himself after power up.
Sometimes when I do a power cycle (on/off/on) multiple times it starts working again.
Unfortunately it falls back into resetting when I'm loading a new a new patch from the G2X memory in one of the slots, not always but quite often.
I wasn't sure if I should but the topic here or into the bug part.
Any ideas?
Audio files: 116
G2 patch files: 317
PostPosted: Mon Sep 03, 2012 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome homers. Annoying problem Confused
If I were me .. I'd open it up and look .. maybe something is loose?
Could it be your power is low, like say 90V instead of 110?
Just some wild thoughts.
homers
PostPosted: Mon Sep 03, 2012 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I already checked the connections and the switch on the power supply shows 110V other synths on the same outlet have no problems.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Sep 03, 2012 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
As in you opened it up?
homers
PostPosted: Mon Sep 03, 2012 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Sep 03, 2012 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn, I'd have to think now Shocked
Pull cables and reseat 'm?
homers
PostPosted: Mon Sep 03, 2012 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok will do and report back tomorrow.
homers
PostPosted: Mon Sep 03, 2012 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't wait until tomorrow open the G2X unplugged all ribbon cables on both sides not only at the mainboard side as I did it the last time and it looks good so far Very Happy Very Happy
Let's for how long it will last.
Derek Cook
PostPosted: Fri Sep 14, 2012 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hopefully a long time. Smile
Connectors can get oxidized over time. The other possiblilty with the G2 engine as it runs quite warm (mine does anyway) is thermal creep of connectors if there are no retaining lugs/straps. As things heat up and cool down they expand and contract which can gradually work connectors/pins out of sockets over time. It happens with chips as well if they are socketed, so it's always giving them a firm push when fault finding.
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
paalolav
PostPosted: Mon Sep 17, 2012 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same problem with my G2X. Talked to a tech who recomended me to change the PSU, which I did. I had a spare one from a Nord Stage. It has worked perfectly ever since. Knock on wood!
homers
PostPosted: Mon Sep 17, 2012 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to mention, that after I put the G2X back in the rack it happened again.
I also found a trick, while doing the endless reboot you have to steady turn one of the continues controller during the reboot which will break the cycle eventually.
It is really strange, I like the idea with the psu but I don't have any spare parts, any idea where I can get one?
paalolav
PostPosted: Mon Sep 17, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Check with your local Clavia dealer. Good luck!
paalolav
PostPosted: Mon Jan 14, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Any updates?
JuneSolstice2013
