Steiner VCF inputs
Page 1 of 1 [7 Posts]
isak
Audio files: 9
PostPosted: Mon Sep 10, 2012 3:33 pm    Post subject:  Steiner VCF inputs Reply with quote  Mark this post and the followings unread
Hi there Smile
i have a noob question..
as i understand the Steiner-Parker Synthacon have 3 vco's.
lets say i have 3 X VCO, how can i connect all 3 VCO's to the LP or BP or HP?
did the synth have more then 1 input for each mode?
maybe the VCO's went to the VCA that have 3 inputs and then to the VCF?
i hope my question make sense.
Isak E.
yusynth
PostPosted: Wed Sep 12, 2012 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
In general one uses a signal mixer to combine the inputs of different signals.
Yves
isak
Audio files: 9
PostPosted: Wed Sep 12, 2012 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi yves and thank you for replying.
Yes, I figure it out.
Took me few days but I got it Smile
Thank you for sharing your cool designs!
btw have another question.
I remember reading that some one had or has a problem with noisy pot, reso pot if I'm not mistaking.
You said that the problem is something with the Steiner design.
he use the CA3096 design.
Does the problem of the reso pot noise is with the 1583 design as well?
Isak E.
yusynth
PostPosted: Wed Sep 12, 2012 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is less sensitive there but is present too. A way to avoid that is to use a high quality cermet potentiometer or a plastic track potentiometer.
I eventually came up with a completely different design of the resonance circuit for this filter that I introduced for the MiniBrute and I will publish it sometimes soon on my site.
Yves
isak
Audio files: 9
PostPosted: Wed Sep 12, 2012 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
isak
Audio files: 9
PostPosted: Wed Sep 12, 2012 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
How much is soon?
I really want to build it Rolling Eyes
Thanks again for your amazing work!
EDIT:
I didn't knew what is the MiniBrute, i google it and found an amazing new synth.
Great job Man, now i really want to build it!
BTW can it work with 12V?
Cardinen
PostPosted: Thu Sep 13, 2012 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I had noticed that when i first tried the minibrute some months ago, the resonance was more stable than my steiner, maybe less wild.
Niio1
