klee resistors
Page 1 of 1 [4 Posts]
owm
PostPosted: Sat Oct 13, 2012 5:36 am    Post subject: klee resistors Reply with quote  Mark this post and the followings unread
I'm in the process of building the Klee ( at a very slow pace....)
and I wanted to ask this to Mr. Stites: On the analog board, the
100K 0.1 % resistors should be 1/8 W, according to the documentation. However, I have 1/10 W units. Can I use these ?
Thanks !
Philip
wmonk
Audio files: 12
PostPosted: Sat Oct 13, 2012 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That will work okay, it's 100kOhm, so you would need 100V across it to get 1/10 W. Not going to happen in the Klee. Wink
Woody
Weblog!
Kits for synthesiser modules in Europe
owm
PostPosted: Sat Oct 20, 2012 9:37 am    Post subject: klee resistors Reply with quote  Mark this post and the followings unread
Hi Woody,
Thank you so much !
Best regards,
Philip
Audio files: 22
PostPosted: Tue Nov 06, 2012 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Another alternative for folks is to take a bunch of CHEAP 100K 1% resistors and match them to within 0.1% of each other. This works well if they are on a reel and are usually matched pretty well.
Bill
