Nord Lead 2 Performance Mode Midi Changes
Page 1 of 1 [2 Posts]
maxpower
PostPosted: Wed Oct 17, 2012 8:42 pm    Post subject: Nord Lead 2 Performance Mode Midi Changes Reply with quote  Mark this post and the followings unread
Does anyone know if it's possible to send program changes to an external midi device by pressing the A B C D buttons while in performance mode?
I can change the patches on another synth by pressing the up and down buttons while in performance mode, but the A B C D will not change anything on the other synth.
Any help would be greatly appreciated!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Oct 19, 2012 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I answered you also somewhere else...
Just pushing the Slot Button only determines which Slot can be controlled by the knobs (in focus, blinking Slot) Just activated (LED lit) means this or these Slots are controlled by the internal Keyboard, so not usefull on a Rack version.
Pressing a Slot to get it in focus and hold the button while using the up&down means it will perform a Program Change to the Slot to the next memory location for that particular Slot and this data will be transmitted IF send/receive is activated on the system menu.
If you are working this awy you better use PCMCIA cards becaus the memory banks have to be the same always...
Wout
Niio1
