Single Buss Keyboard Conroller
Page 1 of 1 [2 Posts]
El Mop
PostPosted: Tue Oct 30, 2012 9:57 am    Post subject: Single Buss Keyboard Conroller Reply with quote  Mark this post and the followings unread
I did a layout of the Single Buss Controller from the MFOS Site
http://www.musicfromouterspace.com/analogsynth_new/SINGLEBUSSKEYBOARD2007/schematicpage1.gif
Here is my layout :
(The numbers at the beginning of the Bill of Material are resistors. Just using only numbers for a better readabilty in the layout.
I used a TL074 instead of the LF444. All diodes are 1N4148.)
Edit: Q1 need to be turned by 180 degrees.
I checked it three times and couldn´t find a mistake,
but today I connected it to the resistor chain to calibrate it
and couldn´t get anywhere near the 0.3959V.
Instead I get voltages from 2.8V till 3.52V, depending on the adjustment of the Trim Pot R3.
Help please!!!
Thank you!!!
aletropot
PostPosted: Wed Nov 14, 2012 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
hum...
I was reading the calibration, and you need to get 0.833A on R5. I have this value..
But then I check the voltage and I have 2.3V too and not the 0.39Vs...
Confused
Niio1
