G2 drivers, compatible with Windows 8?
Page 1 of 1 [11 Posts]
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Wed Nov 21, 2012 10:16 am    Post subject: G2 drivers, compatible with Windows 8?
Subject description: that's the question
Anyone tried yet?
Cheers!
Albert
miketheman
PostPosted: Tue Dec 04, 2012 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope, but interested in that question as well!
It´s either if G2 (engine) + editor will work in Win 7 (32-bit) or Win 8 (32-bit).
Tried to read up on it at Microsoft site, but they´re very vague on this subject.
http://monograss.se
http://monograss.bandcamp.com/
http://thesupervised.bandcamp.com/ (legacy)
Derek Cook
PostPosted: Wed Dec 05, 2012 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would be nice to know. Smile
It may break at some point. I'm learning that Windows 7 has screwed up MIDI support in general (not general midi support! Shocked ).
I have two specific cases with my x.factory Librarians, which also exist if "I go Low" in something like MIDIOX, and try on different MIDI interfaces.
  • in ex.factory, MIDI clock on the Yamaha EX5 MIDI A output stops the reception of SYSEX MIDI data in WIN7
  • in sy.factory, SYSEX sequencer data from the SY77/SY99 is cropped at what appears to be a 256 byte buffer limitation in WIN7.
I don't see these problems on XP or OSX Lion, so there's either a case for keeping an XP boot partition, or completely making the jump to OSX!
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
G2DREAM
PostPosted: Sun Dec 16, 2012 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
the only thing that i can reassure you is that the Modular Editor 3.03 and the Nord Modular G2 Editor 1.62 are working smoothly under Win 7 64 bit...
(except the error every time you close the Modular Editor 3.03 that forces you to kill it from the task manager)...
Cheers...!
jima
PostPosted: Wed Dec 19, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers...!
Hmmmm - that's USB of course. I was just about to push the button on Vista Business x64 to Win 7 x64 but methinks I'll look into the MIDI issues a bit deeper first. Glad I saw your comments, Derek!
Derek Cook
PostPosted: Wed Dec 19, 2012 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers...!
MIDI on OSX is working quite nicely though. Smile
Regards
Derek Cook
www.purefloyd.co.uk
www.carregddu.co.uk
www.ex5tech.com
seb
PostPosted: Sat Dec 22, 2012 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I just installed Nord Modular G2 Editor 1.62 and the 64bit USB Driver 2.16 on my Netbook running Windows 8 Professional 64bit. The G2 still is on OS 1.40. Everything works!
Seb
http://www.myspace.com/sebastianarnold
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Sat Dec 22, 2012 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for reporting back Sebastian! that's very good news Smile
Albert
cappy2112
PostPosted: Sun Dec 23, 2012 6:16 pm    Post subject: Re: G2 drivers, compatible with Windows 8?
dorremifasol wrote:
Anyone tried yet?
Cheers!
Have you even tried W8 yet?
It's horrible. Stick with Windows 7.
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Sun Dec 23, 2012 6:18 pm    Post subject: Re: G2 drivers, compatible with Windows 8?
No, I haven't, but I have read some good reports. I guess it still needs some maturing.
Albert
Vader77
PostPosted: Fri Dec 28, 2012 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm very interested to see how in the touch screen response of Win8 will work with the programmer.
I have an Acer touch screen and the touch screen is responsive however its more the software side of things that let it down so its nothing more than clunky at best on the G2 programmer even at lower screen resolutions unlike the military spec Itronix laptops which work very well with XP.
Niio1
