Pitch Stick Repair - Wire Orientation
Page 1 of 1 [2 Posts]
MiCR0C0SM
PostPosted: Thu Dec 06, 2012 6:24 am    Post subject: Pitch Stick Repair - Wire Orientation Reply with quote  Mark this post and the followings unread
Would anyone be able to confirm for me the wire orientation of the pitch stick to the PCB? I attempted to replace my broken pitch stick in the wee hours of the morning and was unsuccessful. Instead of a drifty pitch stick, I have one that doesn't register at all now (which I do suppose is a slight improvement). I'm pretty sure I lined up the wires correctly but want to confirm. I did take pictures because I wanted to document the process for the masses, but what good is my process if it fails lol!?!
Instead of soldering I crimped using butt connectors, so it could also be my connections. I want to rule out wire orientation dirt though. Next attempt may be to recrimp or venture into the ambitious world of soldering *gasp*.
Estarriol
PostPosted: Fri Dec 07, 2012 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're fixing G2 pitch stick I'll help, post the pics. I've unsoldered pitch stick from PCB and made it detachable.
Niio1
