eem
Posted: Wed Dec 19, 2012 12:30 pm Post subject:
Chuck on the Raspberry Pi? |
Hi all,
Does anyone ever tried/succeeded to run chuck on a Raspberry Pi? It would be the perfect platform for a cheap monitorless OSC/MIDI chuck station!
Nicolas _________________ Electronique et Musique blog |
eem
Posted: Mon Dec 24, 2012 5:35 pm Post subject:
So, here is where I am after some time trying to get Chuck run on the Raspberry Pi.
First thing to do, get chuck:
| Quote: | | sudo apt-get install chuck |
Chuck should install with no problem, but if you try to run it, you would get:
| Quote: | chuck test.ck
[chuck]: (via rtaudio): no devices found for compiled audio APIs!
[chuck]: cannot initialize audio device (try using --silent/-s) |
So at this point I tried to install and run JACK, but for some reason, I cannot manage to start the server. Instead I get a "bus error", and I still have to work this out.
Meanwhile I noticed a "chuck.alsa" installed along with the regular "chuck". So I tried launching my test.ck with this chuck.alsa, and it worked. Good news!
Later on, I tried a sketch dealing with OSC receiving, and it failed, saying "undefined type 'OSCSend'..." So I still have to investigate a bit.. I will let you know!
Joined: Aug 08, 2009 Posts: 556 Location: Upstate New York USA
Audio files: 151
Posted: Mon Dec 24, 2012 7:56 pm Post subject:
I don't have one of these and I haven't done anything with chuck in a while, but your efforts to make them work look interesting. I look forward to reading more of your experimentation.
Steve |
eem
Posted: Tue Dec 25, 2012 8:34 am Post subject:
Ok, chuck v1.3.1.3 is now running on my RPi! Eventually I did not use the binary installed by apt-get. Instead I had to download the sources and compile chuck and other dependencies.
Requirements:
- alsa-lib-1.0.25.tar.bz2: http://www.alsa-project.org/main/forums.html/Download
- libsndfile-1.0.25.tar.gz: http://www.mega-nerd.com/libsndfile/
- chuck-1.3.1.3.tgz: http://chuck.cs.princeton.edu/
Install the ALSA library
On my RPi, chuck compilation failed because of "alsa/asoundlib.h" missing. I realized that whereas ALSA is installed and running properly, the include files are not installed. So I installed alsa-lib:
| Code: | tar -xjf alsa-lib-1.0.25.tar.bz2
sudo ./configure
sudo make
sudo make install |
Then the /usr/include/alsa directory appeared.
Install libsndfile
| Code: | tar -xvf libsndfile-1.0.25.tar.gz
sudo ./configure
sudo make
sudo make install |
Install chuck
I followed the instructions given at http://chuck.cs.princeton.edu/doc/build/:
| Code: | tar xvzf chuck-1.3.1.3.tgz
cd chuck-1.3.1.3/src/
sudo make linux-alsa |
I tested the newly created chuck with some of my sketches, and everything seems to be fine! The performances should be closely monitored though, with quite an high CPU usage.
One last thing, in order to get the sound from the headphone jack output while using the HDMI video:
| Code: | | sudo amixer cset numid=3 1 |
Here it is, I hope this will be useful to others!
Audio files: 211
G2 patch files: 92
Audio files: 151
Posted: Tue Dec 25, 2012 6:22 pm Post subject:
Congrats!!! Glad to hear you got it working. Nice documentation for others who might want to give it a try.
Steve |
witt0191
Posted: Sat Dec 29, 2012 5:39 pm Post subject:
very cool will try this next week
Scott |
