 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
bitstream 3x & monomachine weird talk backs
Page 1 of 1 [3 Posts]
drumfish
PostPosted: Sun Dec 23, 2012 9:03 am    Post subject: bitstream 3x & monomachine weird talk backs
Subject description: bitstream 3x reset the sfx60 to its original values
hi guys
i tried to sort this issue from days, i can't
i browsed many forums on the web, nothing
i find here & there info i already got so ... electro-music is my last chance
before i start, you must make the difference between both joysticks, one from the monomachine & the other from the bitstream & then we can start
1st : i explain
1 : assign menu of the monomachine
2 : joystick R/L & joystick U/D
either 2 pages in mirror mode either 4 pages in mirror off
in "mirror on" i got no problem
so now in "mirror off" :
elektron knobs goes from -64 to +64
bitstream 3x goes from 0 to 127 or 127 to 0
elektron gear needs negative values
bitstream only has positive values
did you manage to tweak these parameter pages in "mirror off" ?
2nd : i ask the question
my problem is that the joystick of the bitstream resets the crossfader & then the monomachine because both cross & joystick only sends positive values when the monomachine joystick needs positive values for the joy up & negative values for the joy down
i hope my thread is not too confusing
only bitstream 3x & monomachine user could help
so please guys, just show up caus' if the bitstream is stuck with this midi implementation i'll have to get an other one & i really like my 3x
Muied Lumens
Audio files: 204
PostPosted: Sun Dec 23, 2012 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Please don't double post. I will remove the other one.
Hope you get your problems solved.
Muied Lumens Base Star
drumfish
PostPosted: Sun Dec 23, 2012 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi lumens,
sorry for the double post
i didn't know replying to an other thread is linked to the thread here
it's same post ... sorry
i didn't solve the problem yet
