Bi-polar electrolytic capacitors vs. polarized
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
KnobHell
PostPosted: Sat Jan 05, 2013 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
lucid wrote:
Does it means that bi-polar (or non-polarized) could be used, just it is more expensive and bigger with the same capacitance?
The Klee schematic is not public, and I don't know if Scott specified a particular type of electrolytic, so there is no way to tell if there is some special situation here. But in general, your statement above is correct. At any rate it's not going to blow anything up, so go ahead and use the bipolars if you like.
Ian
Are not all the current documents here, including the schematics?
http://electro-music.com/forum/topic-24821.html
frijitz
Audio files: 54
PostPosted: Sun Jan 06, 2013 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, so they are. I was confused with the other project.
Ian
KnobHell
PostPosted: Sun Jan 06, 2013 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ian,
Which other project? Is there something cool I need to look at?
len
frijitz
Audio files: 54
PostPosted: Sun Jan 06, 2013 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of the Appendage ribbon controller.
KnobHell
PostPosted: Sun Jan 06, 2013 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
The schematic for that one is in the build manual.
http://electro-music.com/forum/topic-38547.html
Not to hijack the thread.. But is is the board still available? Can the appendage be used with other ribbon controllers? Like the kurzweil?
len
Niio1
