vladosh
vladosh
vladosh
vladosh
Posted: Wed Feb 20, 2013 5:15 am Post subject:
Noise Gate and Compressor (Sqeeze Box) by Seb Francis ,as part of his Box-O-Trix ,more details and the rest of the schematics on his page http://burnit.co.uk/sdiy/forums.html?page=boxotrix from there the brief description on the whole Box-O-Trix :
This is a modular compressor / limiter / distortion / gate unit. It was born out of my desire to have many different flavours of distortion available in a compact format. I'd had enough of my studio space being taken up by old mixing desks, battery powered guitar pedals, etc. just because I liked the sound of overdriving them. So I set about breadboarding many different designs until I found a set that gave me a good cross section of wonderful sounding distortions.
The next thing I wanted to add was a compressor or two - very useful to put before distortion in the effects chain, but I also wanted a super-flexible high fidelity unit to use stand alone as well. One nice feature is that the minimum attack rate goes so low that it makes it possible to introduce lots of self-AM distortion for bass sounds (can be a great effect, similar to a ring modulator). If the release rate is set above minimum then you don't get this effect, but instead you have an ultra fast peak limiter.
40.93 KB |
| Viewed: |
51 Time(s) |
57.63 KB |
| Viewed: |
60 Time(s) |
vladosh
Posted: Wed Feb 20, 2013 10:53 am Post subject:
Sample and Hold by René Schmitz ,visit his pages for more details on this module and useful information on synthesizer diy http://www.uni-bonn.de/~uzs159/ from the description given on his site :
There is not much to say to this, a S&H is frequently used to create random voltages, or to sample LFOs resulting in repeating voltage patterns. When constructing this take care to deflux the board. The S&H can handle the "full" +/-10V scale. Operation is very simple, when the Gate of the FET is at -15 the FET is completely off. Thus no current can flow out of the capacitor (exept some leakage). When the Gate is turned towards +15V the FET is turned on and can charge the capacitor to the input voltage. The circuit on the right converts 5V triggers to the +/-15V triggers needed by the S&H
Jörgen Bergfors has pointed out that with a BF245A and the gate resistor R1 is altered to 47k, the circuit can reach -10V input. (Which isn't always the case in the above version.)
5.12 KB |
| Viewed: |
2726 Time(s) |
4.98 KB |
| Viewed: |
2726 Time(s) |
vladosh
vladosh
Posted: Wed Feb 20, 2013 11:07 am Post subject:
BugCrusher by Tom Bugs ,as presented in this thread http://electro-music.com/forum/topic-13444.html for more visit the Bugbrand site http://www.bugbrand.co.uk/forums.html?main_page=index&cPath=2 from the details on this circuit given on the site :
I'd wanted to make some sort of bit-crusher effect for ages, but never quite figured the way to use microprocessors or ADC/DACs. And then I came across the Analog Devices AD781 Sample & Hold Amp and it struck me that running this at audio rates would effectively give a simple means of changing the sampling rate - not true bit-crushing but it sounds great!
The AD781 is very easy to implement. All you need is a 5v trigger pulse at whatever rate - this must, however, be of very narrow pulses, so I used a 40106 chip (with 5v supply) to make a narrow pulse osc. You also need to keep the pulses narrow to avoid signal bleed through. From this point I added a Voltage Controlled Resistor onto the circuit to make the Trigger Osc voltage controllable. These circuits were designed for my modular system - they run off a +/- 12v bipolar supply
The 1st circuit is the simple stand-alone - simple & very effective. The 2nd circuit adds voltage control to the 1st circuit (along with some tweaks for the particular application). An LM13700 is used for a floating VC Resistor (resistor values found by trial & error!) and this is driven by a log converter based on a Ray Wilson Music From Outer Space schematic.
73.36 KB |
| Viewed: |
33 Time(s) |
106.71 KB |
| Viewed: |
40 Time(s) |
vladosh
vladosh
vladosh
Posted: Thu Feb 21, 2013 1:15 am Post subject:
Buchla 208 by Don Buchla ,from the Music Easel ,as presented in this thread : http://www.electro-music.com/forum/topic-30768.html ,schematic by Scott Stites ,layout by vtl5c3
51.9 KB |
| Viewed: |
62 Time(s) |
564.28 KB |
| Viewed: |
31 Time(s) |
313.39 KB |
| Viewed: |
31 Time(s) |
vladosh
Posted: Fri Feb 22, 2013 12:32 pm Post subject:
Aries AR-312 Envelope Generator ,for more details on the performance of this circuit and the modifications as included in the schematic bellow visit Dave Brown's pages http://modularsynthesis.com/aries/AR-312/ar-312.htm ,more information on the Aries Modular http://www.leinermedia.net/aries/home.html
1.17 MB |
| Viewed: |
32 Time(s) |
1.02 MB |
| Viewed: |
43 Time(s) |
vladosh
vladosh
vladosh
vladosh
Posted: Sun Feb 24, 2013 12:28 pm Post subject:
Percussion Ribbon Controller by Electronic Peasant ,for more details on the construction of this controller visit http://www.electronicpeasant.com/projects/ribbon/controller.html from there the brief description on the circuit and it's functionality :
A 2 foot long piece of 1 1/2 inch diameter wooden dowel was mounted horizontally on the top of an old lamp stand with some angle brackets and wood screws. Along the top of this dowel a length of 1/2 inch mylar adhesive tape was applied. Then graphite powder (the type for lock and key lubrication) was rubbed into the mylar tape until the total resistance from end to end was about 100K ohms. Next, a belt was trimmed to the same length as the dowel. Then a 1/2 inch wide strip of brass shimstock was glued down along the center of one side of the belt. The belt was then attached to the top of the dowel at either end with washers underneath, so that it was suspended over top of the mylar/graphite tape with the brass strip facing down. Electrical connections were made using ring lugs on one side of the assembly.
Next, a basic sample and hold was built for the controller using a FET and a few op amps. The circuit is similar to that which Eric Barbour uses for his keyboard controllers, with a few mods and additions. The electronics was installed in a nifty little plastic box and attached it to the stand just under the ribbon controller. It has three controls; pitch, which offsets the CV output; width, which increases or decreases the CV output range; and glide, which is a basic portamento. There is one LED for power and another to indicate triggering (bright flash) and key down (dimmer steady light). As the whole circuit is just running on a single 15 volt supply, CV output range is from about 1 to 14 volts, which works well with my tube oscillators but which could also be adapted to solid state oscillators if required
4.03 KB |
| Viewed: |
2335 Time(s) |
8.78 KB |
| Viewed: |
31 Time(s) |
vladosh
ChrisLody
Nardu
Joined: Feb 28, 2011 Posts: 20 Location: Braila, Romania
bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
vladosh
Posted: Mon Apr 29, 2013 11:20 am Post subject:
Sample and Hold by Rene Schmitz , more info on this module on the web page : Syntns'r'us http://www.uni-bonn.de/~uzs159/
5.12 KB |
| Viewed: |
702 Time(s) |
4.98 KB |
| Viewed: |
702 Time(s) |
-minus-
Posted: Wed May 15, 2013 2:12 am Post subject:
Is there an index to this somewhere? I'm having trouble finding things.  |
Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Wed May 15, 2013 4:37 am Post subject:
| -minus- wrote: | Is there an index to this somewhere? I'm having trouble finding things.  |
Look at the wiki ... not sure if everything is in it already, but you could add stuff  _________________ Jan |
vladosh
vladosh
Posted: Sun May 19, 2013 11:31 pm Post subject:
Rhythmic Switch design by A. Moskvin
1.93 MB |
| Viewed: |
5 Time(s) |
3.24 MB |
| Viewed: |
6 Time(s) |
2.48 MB |
| Viewed: |
6 Time(s) |
vladosh
Posted: Sun May 19, 2013 11:35 pm Post subject:
Programmable impulse sequence generator ,designed by A. Tochev
796.46 KB |
| Viewed: |
6 Time(s) |
934.12 KB |
| Viewed: |
7 Time(s) |
