Pad Synth and other newbie questions
Page 1 of 1 [3 Posts]
thesoundgrove
PostPosted: Mon Jan 28, 2013 11:15 pm    Post subject: Pad Synth and other newbie questions Reply with quote  Mark this post and the followings unread
Hi chuck community,
I was wondering if it was possible to make a pad synth in chuck and also if it was possible to play two waves at the same time in one shred for example both a sine wave and a triangle wave.
Audio files: 211
G2 patch files: 92
PostPosted: Wed Jan 30, 2013 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, everything's possible! :) To play two waves at the same time, just throw them in there and they will start playing:
Code:
SinOsc sine => dac;
SawOsc saw => dac;
400 => saw.freq;
600 => sine.freq;
0.2 => saw.gain;
0.5 => sine.gain;
1::week => now;
You can look at each UGen (SinOsc and SawOsc are UGens) as kinds of shreds of their own - they'll play by themselves until you shut them off. You can start them in shreds if you want, you can nest them in classes, but their mechanism for playing is independent of which shred started them.
As for pad sounds - pads can sound in loads of different ways, and be constructed in different ways. You might want to start by just experimenting around and alternating with listening to sounds you want to recreate and think about what they might be built from and how. ChucK is great to just play around with!
thesoundgrove
PostPosted: Wed Jan 30, 2013 3:49 pm    Post subject: Thank you so much for yoor a r reply (:u Reply with quote  Mark this post and the followings unread
That will keep me busy for a while.
Niio1
