 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
iConnectMIDI and audio interface at the same time?
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [4 Posts]
GovernorSilver
PostPosted: Thu Jan 31, 2013 8:31 pm    Post subject: iConnectMIDI and audio interface at the same time? Reply with quote  Mark this post and the followings unread
Anybody using both of the above with an iPad at the same time? How are you achieving this, especially if the audio interface is also designed to connect to the dock port, since the iConnectMIDI device also connects there?
Some old stuff on VIRB
GovernorSilver
PostPosted: Fri Feb 01, 2013 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
To rephrase the question:
Anybody use MIDI on iPad AND record to a multitrack app on iPad at the same time?
DES
PostPosted: Sat Feb 02, 2013 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you looking to have Midi from an iPad app (like Meteor for example) control something external like a synth that is then recorded back into your iPad? I use a Presonus Audiobox USB that has both Midi and audio, but haven't tried doing that....yet Smile With the Audiobox I have to use a USB hub and the CCK, but in general the unit works ok. I have used Midi in from Reaper and a controller to control on board apps like Alchemy Mobile, Sunrizer, etc. which then go out the Audiobx back into Reaper.
www.davesneed.com
GovernorSilver
PostPosted: Sat Feb 02, 2013 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
One example application is to run this polyphonic (out of standard mono guitar signal) MIDI Guitar app on iPad - in order to do so, one would need both audio into the iPad, and MIDI output from the iPad to external synth:
http://www.jamorigin.com/midi-guitar/iOS/index.html
Another of course would indeed be to run Meteor to send MIDI to external synth and record the audio into iPad.
