  Muied Lumens Frequencies
Sequencer Linking
Page 1 of 1 [9 Posts]
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Mon Feb 04, 2013 8:47 am    Post subject: Sequencer Linking
Subject description: I forgot how.
Forgot how to link multiple sequencers, shine some light please Very Happy
tiptaptempo
G2 patch files: 16
PostPosted: Tue Feb 05, 2013 10:20 am    Post subject: sequencer linking
Subject description: linking multiples sequencers is my daily job ...
Hej Lfo Head,
Take three sequencers for instance, and one clk gen (in the module LFO)
clk active out of the clk gen into the clk input of the first sequencer.
Then you have just to chain all the sequencers "clk" input together.
After that you chain the "Link" out of the sequencers with the input rst.
you chain the last sequencer out, "link", into the input "loop" of the first sequencer.
It's explained in the manual btw Very Happy
Tell me if it works !!
mulltiples sequencers.pch2
 Filename:  mulltiples sequencers.pch2
 Filesize:  2.11 KB
 Downloaded:  1159 Time(s)
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Wed Feb 06, 2013 6:19 am    Post subject: Re: sequencer linking
Thanks man, works great.
Though im trying to link "SeqCtr" had any luck linking that one? If im not misstaken ive seen it linked before but cant get it done. All ive succeded with until now is to alter the speed of the SeqCtr.
Once again thanks alot man! cheers Smile
tiptaptempo
G2 patch files: 16
PostPosted: Wed Feb 06, 2013 7:27 am    Post subject: that's very interesting Reply with quote  Mark this post and the followings unread
Hej Lfo Head,
that's very interesting, because all my work with the G2 is about linking sequencers and ctr sequencers .... look the link below,
http://www.youtube.com/watch?v=1YE0phGTPpI
the patches are not mine Rolling Eyes , but in this performance there is much of sq lev linked.
I think what you're lookin' for is actually quite the same that linking two, three or whatever note sequencers between them.
BUT ! instead of using ctrl sequencers, just use lev seq, i think it's quite the same. They have more options to be linked.
hope it helps you !
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Wed Feb 06, 2013 9:07 am    Post subject: Re: that's very interesting Reply with quote  Mark this post and the followings unread
Thanks for showing me linking, now its much closer to what i need, or it is what i need, only thing ruining in some cases is when interpolation (steps) is not to be heard.. Tried with all sequencers the only one i dont hear interpolation on is SeqCtrl with XFade.
Once again man thanks alot for ure help i appreciate it alot.
Kind Regards/Lfohead,Gabe
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu Feb 07, 2013 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
SeqCtrl can be linked using offsets.
0-64 units select all 16 steps so if control is -64 to 64, add constant level 64 to one sequencer to make chain. You can also do 4 sequencers if you want.
Unfortunately, with xfade, the fade will always be between steps on the same sequencer so as you go from SeqA step 16 to SeqB step 1, the xfade is between SeqA step 16 to SeqA step 1.
ChainSeqCtr.pch2
 Filename:  ChainSeqCtr.pch2
 Filesize:  1.42 KB
 Downloaded:  1172 Time(s)
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Thu Feb 07, 2013 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing thanks ian,
Nice, now i know i allways thought XFade were between each step.
Or is it only in this situation, hit me if im wrong.. I experiment with Constant Level yesterday, though without luck. I lack alot of knowledge as you maybe already can tell, but hey allways striving to learn no matter how hard or as i use to put it too simple to understand..
Thanks again,
Kind Regards/ Lfohead
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu Feb 07, 2013 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes you are correct, if you chain two sequencers like this, they don't know about each others level settings so they can't xfade from the last level on SeqA to the first level on SeqB. Xfades works as normal between all other steps.
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Thu Feb 07, 2013 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh nice, makes total sense Smile
Thanks buddy
