Roland GR series emulator? GR300 esp
Page 1 of 1 [9 Posts]
phoofk
PostPosted: Tue Feb 05, 2013 9:40 am    Post subject: Roland GR series emulator? GR300 esp Reply with quote  Mark this post and the followings unread
Wondering if anyone has any insight as to the architecture of the GR 300 guitar synth, i just got a Fender with a roland pickup and I want to shred on some Adrian belew kind of "reed"-like, infinite sustain sound that sounds like a clarinet or some arab reed instrument, like snake-charming sound.
feel me?
I'm sure the 300 isn't that complex in signal path, but just wondering if this means anything to anyone in terms of what i'm trying to do.
gr 700 i know is based on JX8P, so perhaps there exists something to emulate that already.
aright! thanks!
Audio files: 211
G2 patch files: 92
PostPosted: Tue Feb 05, 2013 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome phoofk!
You have posted this in a subforum dedicated to Nord Modular synths. Maybe it will get better attention if you post in the "strings and things" forum instead - or a moderator moves this thread there.
Slightly on topic, I don't know anything about the GR300 (I have a VG99), but is that the new Fender with built-in GK mic? Is it nice? Smile
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Tue Feb 05, 2013 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I dabbled a bit with this topic, however with inconclusive results. The thread is here:
http://www.electro-music.com/forum/topic-32369.html
First of all, you have to be aware that the GR-300 is a totally different beast than any guitar synthesizer that came after it. All later designs work via the MIDI protocol, meaning that the sonic activity of the the guitar strings is converted into digital MIDI note and pitch-bend information (and perhaps more), which then drive a synthesizer module probably optimized for this kind of performance. This approach has benefits and drawbacks. The benefits are that a guitar thus can theoretically drive any kind of MIDI sound generator, and the MIDI data can further also be recorded and manipulated in any way. The drawback is that this conversion introduces noticeable latency, which however was optimized with every new generation -but still is always present.
The GR-300 works totally differently, in that the activity of the vibrating strings actually forms a vital part of the actual sound generation. In a nutshell, the GR-300 features six incomplete sawtooth oscillators (one per string) -incomplete in that they do not have a built-in comparator that will discharge the core capacitor when a certain voltage is reached. So actually, they don't oscillate by themselves at all. They are, however, hard-synchronized to the zero-crossings of the waveform produced by the corresponding string. So actually it's the vibrating string that will trigger the discharge -the string becomes part of the oscillator. Simple, genius. Inevitable frequency-depending differences in amplitude are dealt with simply by hard-clipping the waveform, which produces that characteristic squelched sawtooth sound. This primitive and genius concept makes the GR-300 still unmatched in playing response to this very day. There is literally no latency at all. The drawback is that you are basically stuck with one sound -the GR-300 sound so to speak- which nowadays is more or less owned by Mr. Patrick Bruce Metheny. Laughing
Hard-synching an oscillator to an audio source is laughably simple -just patch the audio source into the sync input. In fact, that's exactly what the Moogerfooger FreqBox pedal does, although it adds FM for extra sonic manipulation. However, the FreqBox is only monophonic. The GR guitar synthesizers had pickups for each string. Also, if you want accurate pitch tracking, this simplistic method will not always work, as harmonics will often produce extra zero-crossings in the waveform, resulting in discrete pitch jumps of the driven oscillator . The GR-300 had an extra circuitry to filter out harmonics and ensure that the fundamental frequency is dominant.
t
beer
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Tue Feb 05, 2013 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Addendum: It just came to mind that the G2 has only 4 audio inputs, so using a hexa-pickup will not completely work.
In terms of pitch-detection on the G2, I (involuntarily) have become somewhat of an expert in this field, having tried out many approaches, of which almost all have failed somewhat Laughing.
The best solution I've ever hit upon uses the stock G2 pitch-detection module with some extra circuitry to help differentiate between periodic and aperiodic signals, in order to combat those annoying blips and glitches that occur when the pitch-detector tries to latch on to chaotic transitions.
To be found here:
http://www.electro-music.com/forum/topic-52784.html
beer
Audio files: 211
G2 patch files: 92
PostPosted: Tue Feb 05, 2013 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of the first things I tried when I got my Nord Modular (the old one) was hook up a guitar to the sync input of an oscillator and then use an envelope follower to amplify. Simple mayhem and fun! Smile
phoofk
PostPosted: Tue Feb 05, 2013 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry ha -
I am using a guitar that has a GK pickup, then a GK to MIDI converter that is USB. from there I send MIDI to the G2 (yes i forgot to mention, i do indeed own one and am attempting to apply this knowledge gained TO it.)
so really the question is not about guitar related anything, but rather, what is the architecture of the roland synthesizer that was used to playback data gleaned from shitty HEX pickups in the 70s/80s.
clearer?
phoofk
PostPosted: Tue Feb 05, 2013 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i really wasted your time eh Tim? huge response, huge effort. so touching. but alas, yes, the tracking/pickup/guitar part of the formula is taken care of.
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Tue Feb 05, 2013 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Easy mate, no need to get emotional Laughing. You asked about the GR-300, I answered -that's all. Wink Huge effort -no. I type fast, and it was actually nice to revisit and rethink some older patches over dinner. Pitch-tracking is a fun subject.
beer
GovernorSilver
PostPosted: Thu Feb 07, 2013 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
To be found here:
Hail the Master
I'm quite satisfied with the modeled GR-300 inside my Roland VG-99 - very easy to get those Pat Metheny/Robert Fripp GR-300 lead tones and Andy Summers chordal washes.
However, I'm going to try your patch with my viola.
VIRB site
Niio1
